Fuel Pump Fuse ??
Old May 9, 2008 | 08:27 AM
crignaj's Avatar
crignaj
Default Fuel Pump Fuse ??
I'm wanting to install a kill switch in my 98 A4, using the electric fuel pump as the shut off. I pulled the fuse cover from the panel in the passanger side footwell & under the hood, but did not see which one is for the fuel pump. Did I miss it ??
If anyone has a better idea on a different method to my kill switch idea, I'm open to listen to it as well.
Old May 20, 2008 | 09:28 PM
crignaj's Avatar
crignaj
Anyone ??
Old May 20, 2008 | 10:26 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Look under the hood on the passenger side. You can also interrupt the fuel pump by intercepting the relay trigger wire under the hood.
To Fuel Pump Fuse ??
