No start problem cured
Old May 18, 2008 | 01:23 PM
LSCHMIDT's Avatar
LSCHMIDT
Default No start problem cured
I had an intermittent no start problem on my 98 6 speed. After replacing the starter solenoid and cleaning all the connections I could think of, I pulled the ignition switch. I tried to disassemble it but the little springs in there flew out and I couldn't find all of them. The contact points in the switch were somewhat corroded. So I purchased a new one and so far after about two weeks of use it has started every time. Just an FYI.
Old May 18, 2008 | 02:59 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
As the C5's get older, that's becoming a more common problem. Thanks for sharing the fix!
Old May 18, 2008 | 06:10 PM
87SAM's Avatar
87SAM
Thanks for the update.
To No start problem cured
