Help - Right side brake lights not working
Was told about my right brake lights being out at a stop light last week so I bought two new bulbs and installed them; still nothing.
Both sides' blinkers still work however, and both sides light up dimly as normal with the headlights turned on.
But the right side doesn't light up for brake or hazards.
I've done some searching and seen similar issues with people when their turn signal lever or their hazard button needs to be replaced. The hazard button seemed to be operating normally to me. It operated the same whether I just pushed it once and let it flash, or held it all the way in.
I have noticed that since I've had the car when making a turn, if I don't lock the turn signal switch all the way down into the R or L turn blinking position (like when I just push it enough to activate the signal), that it blinks twice as fast. Is this normal?
What should I do next to diagnose this problem?
Also, there seems to be some weird problem with my "RANGE" calculator on my fuel dash tab. After just filling up it will say "LOW" for a while, then it will take a few minutes to climb up to anywhere from 500 to 300 miles, and then fluctuate all over the place for a while. I know I can't trust it. Out of the blue before it has dropped to "LOW" from a quarter of a tank.
Is there a common ground for the right brake lights and fuel sending unit?
This is probably a stretch but is there any chance that the new hazard switch was faulty right out of the box?
What should I try next?
My inspection is expiring soon and I need to get this fixed.
Could a generous owner of a 1999 service manual take a few shots of the pages required to replace the turn signal lever?
