Is catch can needed ?
Old May 29, 2008 | 10:18 AM
joels's Avatar
joels
Default Is catch can needed ?
I plan to do HPDE 3 to 4 times a year. Will catch can help engine last longer and perform better? Thanks for your input.
Old May 29, 2008 | 03:04 PM
Dave68's Avatar
Dave68
Theoretically, yes and yes. As far as I know, no one has used one for 200,000 miles and then torn apart the engine to see how much less carbon has built up on the pistons, but essentially, an intake manifold was never intended to be sprayed with engine oil.
Dave
Old May 29, 2008 | 03:06 PM
ragtopws6's Avatar
ragtopws6
Since nobody has responded to this I'll give you my $0.02. I added a catch can because of the following:
1) the engine burns the oil vapors
2) The pistons and the intake valves get coated with oil residue
3) The intake manifold always has some oil sitting in it
4) It just looks better
As for your other question, it can't be healthy for the engine to ingest all that oil!
Old May 29, 2008 | 03:22 PM
JOEY P's Avatar
JOEY P
Depends on what year and mannual or automatic trans not all vettes need catch cans....
Old May 29, 2008 | 03:24 PM
vsocks1's Avatar
vsocks1
How about 2003 Z06?
Old May 29, 2008 | 03:26 PM
JOEY P's Avatar
JOEY P
I dont think so only 2000 and 2001...But I may be wrong somone will chime in if I am.
Old May 29, 2008 | 09:39 PM
Dave68's Avatar
Dave68
Pretty much all GM, Ford, and Chrysler V8s, regardless of year. Supercharged models, as a general rule, produce more blowby and hence, more oil into the intake.
Old May 29, 2008 | 09:49 PM
slvr76's Avatar
slvr76
This is what came out of my catch can the first time I emptied it in my 00' FRC after H/C install.
Old May 30, 2008 | 05:52 PM
JOEY P's Avatar
JOEY P
Again if he is not loosing any oil at any time why would you need a catch can.....I dont have one on my car and have no problems with oil consumption.
Old May 30, 2008 | 07:09 PM
ZeeOSix's Avatar
ZeeOSix
Street driving an racing on the track will cause much different oil vapor flow through the PCV system. Guys who road race can get a large amount of oil in thier catch cans during one track event.
If you drive mellow around town, then the amount of oil vapors will be much less.
To Is catch can needed ?
