Well I jacked it up to 19" (at the jackstand) (about 20" at the lowest point on the rear carriage) I didn't like the way it looked....it was too high....that makes me nervous. So I lowered it back down...now I'm at about 17" at the lowest point on the rear carriage. Looks to be plenty of room to slide the rear carriage out with the tranny jack. So just to clarify, if I don't have trouble removing the cradle this height should be good for everything else, correct?
Also I notice that there isn't a whole heck of a lot of wieght on the front suspension with the wieght on the jack stands. Does this make anybody nervous?
Is anybody aware of a how-to write up that involves the removal of the auto transmission independent of the torque tube? I'm just curious how one accomplishes the removal of the bell-housing bolts (if that is what that is called). Even with the torque tube lowered it looks like this will be difficult as it apears it can only tilted a few degrees (worth a few inches at the back).
18-20" of height should be enough. There's actually a fair bit of room around the rear-end and transmission once you get the rear cradle and exhaust out of the way. There's more room to get the transmission off the torque tube then there is to get the torque tube off the engine.
The exhaust will come out no problem once you get the rear cradle off so having a lot of height for that is not an issue. Once the cradle and exhaust is off the transmission and rear-end can be pulled and then turned to come out the side through the wheel well opening. Lots of room to pull it out there when it's still on a jack.
Before you remove the rear bell housing bolts, you have to remove the bolts that attach the convertor the the flex plate in the torque tube. Remove the rubber cover on bottom of rear bell housing & front bell housing. Turn flywheel with 15mm wrench till you see the bolt that holds the convertor to flex plate, there are 3 bolts holding the TC. Thats all you have to do with the torque tube.
There is less room on an A4 to get to the top bolts, but it can be done, just takes a few minutes.
How high is your front end? My earlier quote of 19 inches, I should have made it clearer, was for all 4 jacking points. If your front is lower, it will make for more clearance in back.
As for pucks, they don't work with heavy jacks. Harbor freight has some rubber covers for the jacks, I would suggest getting them.
Is anybody aware of any DIY how-tos for changing the transmission fluid? How did you guys top off the fluid once you installed the new converter and cooler?
Here is a thread I read about changing tranny and diff fluid. It will make it easier getting to fill the tranny with fluid. Good luck
Why are you changing the TC anyway ? And to what ?
I'm changing the rearend and converter in my car because of the absolutely dismal performance of the A4 equipped vette (most turbo charged 4 poopers today will absolutely destroy the A4 vette in the 1/4) The converter I'm going with is the Yank SS3600. I had been toying with the idea of swapping out the 3.42's with 3.73s as well, but this will have to wait. In addition, I've recently installed heads and cam and the loose converter should help a bit with the idle.
I appologize if I was too harsh on the vette....I'm not afraid to say that the emperor is naked. I had a run-in with a WRX STI awhile back and I didn't like the outcome at all. We didn't run the whole 1/4 mile but the WRX ripped me so far out of the hole all I wanted to do was bury my head. Also had my nephew with me and he lost total respect for the vette....now I can't have that can I?
Ok I was wondering why you were taking out your SS3600 listed in your signature. I guess you installed it in your sig. first.
I'm at the dragstrip every week; and have seen these "turbo charged 4 poopers" that you speak of - barely break in the 13's .
A stock C5 A4 with 3.15 should do 13.2 to 13.3's all day long on factory tires.
your planned upgrades will make a big difference; But I think you're mistaken about what a stock C5 A4 can do.
Unfortuneatly I'm running 2.73s. It would have to be a good day for my car (stock) to break into the 13's. Can't even chirp the tires from a dead stop....that is about to change with my 3.42's and 3600 stall!
Hey Mike, I'm kind of following your how-to. What seals do you recommend I replace? The rearend is z06 unit from a '04 and has less than 10 miles on it. I was thinking to replace the front pump seal, rear shaft seal and the seal plate seal....any idea what the part numbers are?
I responded to your PM.
Bring it out to the track. Totally stock C5 A4's with 2.73 run 13.4 to 13.5 all day long.
