help no ac vacum problem
Old May 31, 2008 | 01:41 PM
tonycorvettehd's Avatar
tonycorvettehd
Default help no ac vacum problem
1998 convertible no ac,my dealer wont work on it,because its over 10 years old,brought it to a goodyear place,they worked on it atleast 6 hours,,they gave up and told me to bring it to a dealer ,that it has a vacum problem,,,helpppppp what can i check or do to find the trouble????thanks guys,,,,tony
Old May 31, 2008 | 02:44 PM
tonycorvettehd
Default info
the ac was checked for refrigiant and i wasted my money with a new climate controll mod,i replaced,it blows hot air and out all the vents all the time,,,i did notice some batter corrosion awile back and put a new battery and hosed the corrosion area,to clean it away,,i just bought the car and inherited this trouble,
Old May 31, 2008 | 03:13 PM
navy99vert's Avatar
navy99vert
Cruise-In VIII Veteran
You said you just bought the car right? Do you know in the intake has been taken off the car? It sounds to me like the vacuum line on the back of the intake has come off or not reinstalled if intake was off. Maybe the previous had an intake swap or oil press sending unit problem.
Old May 31, 2008 | 03:36 PM
tonycorvettehd
Default yes
i just picked it up,the mech said he found some part of the vacum line bad,he fixed that,but he said he doesnt have vacum from the engine to the check valve,and he cant reach behind the engine to find it,,????????what can i check?also the oil pressure gauge is pegged when i bought it ..and still is
Old May 31, 2008 | 03:41 PM
backnblack2003z06's Avatar
backnblack2003z06
The vacum line runs to the back of intake on the right (passenger) side. You may find it easier to take the intake off, but you can get back there its just really tight.
Old May 31, 2008 | 03:47 PM
navy99vert's Avatar
navy99vert
Well sense you need to replace the oil press sending unit. you will need to pull the intake off any way. there is a tiny vacuum line on the back of the intake. When you pull the intake you will see why it gets over looked very small and hard to put on I know some people add a small peace of rubber line to it to make it longer and easier to attach. As far as I know it can't be attached with to intake on. So replace the oil press sending unit at the same time. You can kill 2 problems at once.
Old May 31, 2008 | 03:51 PM
navy99vert's Avatar
navy99vert
this is a LS1 how to on head and cam swap, but it shows you how to pull the intake
http://www.ls1howto.com/index.php?article=1
Old May 31, 2008 | 04:33 PM
tonycorvettehd
Default ?
im not having any other problems,is the ac the only thing that uses that vacum?
Old May 31, 2008 | 04:39 PM
navy99vert's Avatar
navy99vert
As far as I know the AC is the only thing that vacuum line runs, Maybe someone will correct me if I'm wrong. I will go get me service manual of the garage and look it up.
Old May 31, 2008 | 04:51 PM
tonycorvettehd
Default path
do you think it is a straight run ,from the back of the engine to the check valve,?and can a person get to the check valve without taking off the fender?
Old May 31, 2008 | 09:02 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
No, you'll need to take off fender. The other line is behind the intake mainfold and you'll have to take that off too.
The long black cannister by the door.
Old May 31, 2008 | 09:10 PM
backnblack2003z06
Just take out the front wheelhouse filler panel. No need to remove the fender. As per the service manual.
Remove the RH front tire and wheel assembly. Refer to Tire and Wheel Removal and Installation in Tires and Wheels.
Remove the RH front wheelhouse filler panel. Refer to Wheelhouse Filler Replacement in Body Front End.
Remove the PCM. Refer to Powertrain Control Module Replacement in Engine Controls.
Tape off the rear edge of the RH fender and the front edge of the RH door to prevent scuffing.
Open the RH door.
Utilizing the opening between the fender and the door, remove the screws retaining the vacuum tank (1) to the hinge pillar (3).
Working through the wheelhouse opening, disconnect the I/P harness vacuum connector (4) from the vacuum check valve (2).
Disconnect the engine harness vacuum connector (5) from the vacuum check valve (2).
Remove the vacuum tank (1) from the vehicle.
Disconnect the vacuum check valve (2) from the vacuum tank (1).
Old May 31, 2008 | 10:48 PM
tonycorvettehd
Default routed ?
how is the vacum line routed from the engine to the check valve?upstairs or down below?how?,,,and id that the feed from the engine,the bottom one?in the picture
Old May 31, 2008 | 10:51 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Vaccum line runs to canister from the back of the intake manifold.
Old Jun 1, 2008 | 02:40 AM
tonycorvettehd
Default ok
i took out the battery and battery holder,i can see and hold in my hand two vacum lines ,just the ends comming from the vacum check valve,,,now where do they go,,,i dont see any other sides laying around any where////////i guess one goes to the engine ,but where does the other go?
Old Jun 1, 2008 | 04:02 AM
dougbfresh's Avatar
dougbfresh
You really should get the $100 manual-you probably spent several times that taking potshots already. The intake is relatively easy to R&R-do that 1st, bet that vacuum line is broken.
Old Jun 1, 2008 | 09:38 AM
c5streak's Avatar
c5streak
One line should go into the wiring harness, up the back of the engine to the manifold. The other is probably the one that goes through the firewall to the HVAC controller. The one going to the manifold is a pain to replace/repair because it is buried in the harness, much easier to just run a new line. I bet your battery leaked acid and ate the two lines up. You definitely need to neutralize the acid and repaint your frame damage if any. Also check your PCM and connectors for any acid damage and repair that too. Here's a good link with before and after pics of acid damage. Good luck!
http://forums.corvetteforum.com/show....php?t=2031816
edit: Check out the last pic in post #8 of this thread to show you which lines go where from the vac cannister.
http://forums.corvetteforum.com/show....php?t=1966898
To help no ac vacum problem
Old Jun 1, 2008 | 02:11 PM
tonycorvettehd
Default thanks
i found the side that goes thru the harness,i guees thats the vacum from the engine,,question,,how is the one that goes to the car routed?is it in the harnness also?
Old Jun 1, 2008 | 02:30 PM
c5streak's Avatar
c5streak
I may be wrong here but, I think the line goes thru the firewall next to the wire harness that goes thru the firewall also, under the batt tray. I don't think it's actually in the harness. Someone flog me if I'm wrong!
Old Jun 1, 2008 | 03:31 PM
tonycorvettehd
Default well crap
i repaired all vacum lines and the modes are working now the air blows and blows where i want it to but its not cold
