Vararam VS. SLP BLackwing???
Hang tough Dude. As I advise anyone who will listen, just get a tube of Locktite silicone from Walmart and run a bead around the top of the filter and put the filter in the upper housing. Then fill all the gaps around the filter and foam. Do a nice job of sealing it and try not to make a mess. hehehe. Anyways let it dry over night. Nothing can possibly get past the filter. I've cleaned mine twice so far and it isn't much of a hassle at all.
Depending on what you paid you may want to test it BEFORE gluing the filter in just in case you want to return it but I bet you keep it.
You won't regret it once you start driving it.
I couldn't wait and installed the whole system starting at 11:30pm last night. I spent about 3 hours all together I think, but it was worth it. I took the car out for a spin last night around 3am, and I could certainly feel a difference, especially accellerating at highway speeds. Whoa! Now I'll get my mechanic buddy to adjust my tune a bit to thicken up the air/fuel ratio, and I should be quite good to go.A nice gentleman from Vararam finally called me back this morning. They got busy yesterday, and I was in a hurry, so it's no fault of theirs at all. He did tell me the new Green filter along with their system was designed to seal up quite well. Apparently the filter surround is made of rubber, and when the whole system is installed in a car, it squeezes together where the filter meets up with the other parts, thus creating a good seal. He also said the pressure test their systems to 20psi. I'm told the gasket around the inside of the airbox is really just to hold the filter in place... the sealing comes from the filter being squished between airbox and ram tubes once it's installed. As far as the ram tubes gaskets being too big, he says they're supposed to be that way so when the air box comes over and latches down, the gaskets being too big will help to create more of a seal. As for two of the gasket holes for the screws being off, he couldn't explain that.
I still didn't want to take chances though, so I ran a nice soft foam rubber weatherstripping piece around the inside edge of the box so the filter would seal up better.
Here are some other pics related to my installation.
I know the gasket goes sticky side down. I had white side up for the pic so the screw holes were more obvious.
In this photo, it seems like the lower gasket pieces aren't cut properly, but I guess they're working ok.
Seeing this bow creating a gap in the middle kinda bothered me. Hopefully the gasket they provide helps seal this up.
And here it is fully installed
After having many concerns, feeling the need to add more gasket for a good seal, and questioning the overall build quality... I wouldn't return it now for anything. I'll check it after a couple weeks of driving and see how the gaskets are sealing and check for any dirt in the air box. Despite the above concerns, once it's installed it's a very nice piece. And the performance gains speak for themselves! Installation wasn't too bad. I just spent a lot of time getting it just right and cleaning parts of the car while I was down there. Hopefully in the future their apparent overall build quality will increase, but it's a great unit and I'd recommend it.
I think it cost $150 worth of labor. Besides, I was too lazy.
My vararam seemed to line up very well and the green filter sealed pretty good. Just for added peice of mind i ran a bead of black RTV sealer around the filter.
http://home-and-garden.webshots.com/...63776698mQcwBU
After removing the stock airbox and inspecting it, I've come to the conclusion that any type of intake will be better than the restrictive stock one: just depends on how "much better" you want it to be, how you want it to look, cost, and how easy you want the installation to be.
