Fixed key FOB problem
Old Jun 5, 2008 | 03:18 PM
Svelte_C5's Avatar
Svelte_C5
St. Jude Donor '09
Default Fixed key FOB problem
When I bought my 99, the key fobs never worked right. The seller even included for an extra brand new one from the dealer but that one wouldn’t work very long either. They were the ones with the passive unlock switch on it. I would program it through the DIC and it would only work for a few hours, then nothing. I tried everything, brand new batteries, cleaning the battery contacts. I even had the dealer test them on their little fob testing machine (they tested fine).
I did some research here and finally ordered one from a 2000 model without the passive unlock switch, programmed it and it has worked fine ever since. Hope this helps.
Old Jun 5, 2008 | 04:15 PM
lp2k's Avatar
lp2k
good information since im in a 1999 as well
hey FYI, i wear a baseball hat when i drive and i throw it on the dash directly over the sensor (not on purpose) but anyways when the hat is there it dosnt re-act to my FOB
maybe the contact there could be a weakpoint?
Old Jun 5, 2008 | 05:35 PM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
The receiver for the keyless entry is over the left rear tire.
To Fixed key FOB problem
