power shifting
Old Jun 7, 2008 | 10:08 PM
GREG O.'s Avatar
GREG O.
Default power shifting
Does anyone power shift ??? If so tell me what to buy to make it hapen!
cause my b and m won't let me do it !!
Old Jun 7, 2008 | 11:43 PM
BlackZ06's Avatar
BlackZ06
Your shifter is basically a metal stick in a mounting .... it has no clue what you are doing ... and if it had a clue ... couldn't do anything about it.
Maybe if you gave a description of what you mean by "power shifting" and what is happening to prevent you from doing a "power shift" someone can help you ....
It ain't your B&M ....
Old Jun 8, 2008 | 09:54 AM
GREG O.'s Avatar
GREG O.
Stephen, I just want to keep the gas pedal to the metal at all times and POWER SHIFT into 2nd 3rd and 4th. Heck in the 60's on your Muncies and Ford top loaders u could buy a good competition plus,vertical gate or other similar shifters and power shift very easily. I'd like to find a shifter that could do that. B&M sucks. The stock c5 shifter is capable of power shifts, but getting that rubber shifter into the right gear like 3rd.can be a b!tch. Can anyone on this forum POWER SHIFT with confidence?? and what are they using?? btw I still have the skill needed they say '' a poor carpenter is one who blames his tools '' I am not a poor carpenter, just need a quality shifter
Old Jun 8, 2008 | 10:30 AM
bumble-z's Avatar
bumble-z
When I bought my Z new, and had it's required breake in period out of the way, I had a problem power shifting from 2nd to 3rd. Switched out to a Hurst and no problems since. According to posts by RANGER however reccommends a series of defined practice sessions, to get acclemated to your clutch and shifter, hand machanicss.(all done w/out motor running.) Good luck.
Old Jun 8, 2008 | 12:11 PM
Warp Factor's Avatar
Warp Factor
Yeah, the old 4 speeds were easy. For third and fourth, you just pushed to the right as hard as possible when shifting. Doesn't work on a 5 or 6 speed.
A shifter with a 5-6 lockout would be handy. I fabricated one for a 5 speed once because I was having the same problem.
Otherwise, practicing with the engine off is good advice. I never powershift without some anxiety though!
Old Jun 10, 2008 | 09:30 AM
BlackZ06's Avatar
BlackZ06
I haven't tried power shifting with it, but I have a Hurst shifter and have always been pleased with the "accuracy" I have in shifting it. Possibly someone in your area has a Hurst installed and will let you try it.
The Hurst has two advantages ...
1) It comes with springs that can be changed to alter the "centering force" that is applied when you are in the "neutral" position.
2) If you're a car guy from the 60's or 70's .... what's cooler than having a Hurst shifter in the car ???
Old Jun 10, 2008 | 09:40 AM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
How difficult is it to change out the shifter? Is there much tweaking needed once it is installed?
Thanks,
Eric D
Old Jun 10, 2008 | 10:07 AM
BlackZ06's Avatar
BlackZ06
Not difficult at all. The most time consuming part is removing the trim panels ... especially if it is the first time you have done it. You have to remove the console (that compartment under your right arm when you're in the drivers seat) and the trim panel around the shifter (which you'll see goes up and around your radio and A/C controls). Not hard ... just take your time.
Swapping the shifter is literally a 2 minute job .... unbolt old shifter .... bolt in new shifter (you have to transfer a plastic part from old to new .... 5 seconds ....) it is the "a caveman could do it" part of the whole operation.
Then you reinstall the trim panels and
Once you are done with the test drive (which may take several hours because you will LOVE the feel of your new shifter) ....
Go home and
Old Jun 10, 2008 | 10:48 AM
robz's Avatar
robz
I'm sure you already know its hard on the trans.
The best way to practice is to drive on the street at very low rpm and don't lift on the gas and after a while you'll be conditioned to not lifting.
Powershifting can help ET but may also hurt et if traction is not available. Alot will depend on tires and track conditions. Even on slicks you can get overspin on the shifts hurting et. Plus you need to time it just right so as not to hit the liiter and get off the clutch fast. It takes time to get it right and the penalty of a trans damage isn't always worth it. You will likely pick up a mph or 2 however.
Old Jun 10, 2008 | 11:09 AM
nickolbag's Avatar
nickolbag
Practice and timing. You can do it with any shifter. I had the Hurst and was getting close to having it all figured out. If you can do it smooth I'm not convinced it's any worse on the car than lifting. I'm switching to the c6z shifter before the fall season cause I wanted a smoother shift. We will see if that makes it any easier.
Old Jun 10, 2008 | 11:25 AM
98vettedave's Avatar
98vettedave
I hope your right about the power shifting not being worse on the tranny than speed shifting. Now, if your wrong you will need a lot more than a "nickel" in that bag.
Old Jun 10, 2008 | 11:46 AM
nickolbag's Avatar
nickolbag
I've seen people that never miss a shift powershift hundreds of 10 sec passes on stock transmission without problems and then there are the people that can't drive that blow up built transmissions once a year. I think if you shift it good you will be in good shape.
However, I saved up more than a couple nickels in the emergency transmission fund......built or stock, power or speed shifting, you still never know when it's going to give out on you.
Old Jun 10, 2008 | 12:33 PM
98vettedave
I agree you never know when that breakage problem will happen. The guys that are power shifting,do they power shift for all three shifts? The 1st gear to 2nd gear shift seems like it would be really tough on the tranny.
Old Jun 10, 2008 | 12:52 PM
nickolbag's Avatar
nickolbag
Yea they powershift every gear. Now if you lift on the 1-2 it will be easier on the trans but then it is just that much harder on your rear, right?
Old Jun 10, 2008 | 03:45 PM
vetteman9368's Avatar
vetteman9368
From: I have no tolerence for liberals and fools, but sometimes i repeat myself
CI 3-5-7-8-9 Veteran
St. Jude Donor '08
i have a B and M and can powershift just fine. For the record hurst and B/M are the same company now
Old Jun 11, 2008 | 08:44 AM
K RIPPER's Avatar
K RIPPER
When at the dragstrip I speed shift, if I hit the limiter the E.T. suffers considerlby,since you want to get every last ounce of power you rev it to the limiter trying not to hit it,when power shifting the engine flairs during shifts ,how do you avoid hitting the limiter,or do you hit the limiter so momentarily that when the motor hits the next gear its out of the limiter ,or do you anticipate hitting it & shift early, whats the procedure the better power shifters use?
Old Jun 11, 2008 | 12:32 PM
Eric D's Avatar
Eric D
What are the primary advantages in the Hurst shifter over the stock shifter? Is it just looks or are there major mechanical differences?
After reading some of the postings, I am curious what benefit I get for the $200+ for a Hurst shifter over the stock unit.
Thanks,
Eric D
Old Jun 11, 2008 | 08:36 PM
cruzc5frc's Avatar
cruzc5frc
at locals letting you power shift their vettes
To power shifting
