C5 Signal light issue
Old Jun 8, 2008 | 07:14 PM
ynotsquare's Avatar
ynotsquare
Default C5 Signal light issue
I was wondering if anyone has had this problem: my signal lights works randomly. At times, it works for weeks without a problem. Then out of the blue, they will not work for a day. I know it's not the fuse or the bulbs because the daytime lights are running fine. Help.
Old Jun 8, 2008 | 07:24 PM
rws.1's Avatar
rws.1
Yes it is a very common probelm. the bizarre thing is that the turn signals are wired thru the hazard flasher....
Here is the link to the easiest fix.
http://myweb.cableone.net/kd5fx/HSwitch/HSwitch.htm
Old Jun 8, 2008 | 08:54 PM
ynotsquare's Avatar
ynotsquare
Thanks, rws. Seems like a lot to do for a flasher. Oh well. It has to be done.
Old Jun 8, 2008 | 09:47 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
For what it's worth, I just finished changing mine last Friday. It really wasn't as bad to change as I first thought. The hardest part was guiding the new one back in place. Part of the problem was my fat fingers! The turn signals work great now!
Hope your swap goes smoothly,
Eric D
Old Jun 8, 2008 | 10:34 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
I would change your drl's and flasher bulbs
it will solve most likely solve your problem.
Old Jun 8, 2008 | 10:42 PM
stormrider's Avatar
stormrider
Mine went out last night and I just had my emergency flasher replaced less than a month ago. I removed my knee bolster, checked all the connections, gently tucked all the wires under the dash and low and behold the blinkers started working.
Old Jun 8, 2008 | 11:59 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
Sometimes a glue like material will melt at the connector and cause intermittent failure.
Best to check the connection for corrosion or the melting prob.
To C5 Signal light issue
