Need Quick Assistance Please.
Old Jun 14, 2008 | 01:38 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
Default Need Quick Assistance Please.
Help me not get ripped off.
My Belt looks like it is fixing to slip off the drive belt tensioner.
I also have a chirp issue.
I sprayed wd40 on the ac idler and ac tensioner pulley and it stopped chirping for a few seconds.
The stealership wants to charge me 80 bux for one pulley and 60 for another.
What do i really need to purchase? Am i correct to say the ac idler pulley is the same part used on the ac belt tensioner minus the assembly of the ac belt tensioner?
thanks for the quick replies
was told 140 in parts for ac tensioner and idler anothe 100 or so in labor.
is this bs ? I called napa and they have the idler for 18 bux
Old Jun 14, 2008 | 03:54 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
Looks like i have to replace the harmonic balancer for the second time.
Could someone refresh my memory. This is an Auto.
I recall something about adding or using a powerbond underdrive pulley.
Does this replace the harmonic balancer ?
Old Jun 14, 2008 | 07:12 PM
randy814u's Avatar
randy814u
http://forums.corvetteforum.com/show....php?t=2052633
Old Jun 15, 2008 | 08:43 PM
JCSZ51's Avatar
JCSZ51
Cruise-In IX Veteran
I went with the summit udp (yes a udp replaces the factory balancer) and am quite happy with it.
Let me know if you need a hand!
Old Jun 15, 2008 | 11:48 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
Hey thanks alot
I actually pulled it from the stealership and took it to NTB and had them do it.
I ended up with oem balancer and really wish i had thought it over a minute more to wait and order the under drive balancer.
Unfortunely my chirp sound is still there and have left it again for replacing belts and possible the ac idler or ac tensioner
Old Jun 16, 2008 | 04:56 PM
JCSZ51's Avatar
JCSZ51
Saw a white one at NTB on my way to dinner Sat night, wasn't yours was it?
Old Jun 16, 2008 | 05:21 PM
jovette's Avatar
jovette
I recall reading recently that the C6 idler pulley will work on the C5, and the C6 is better because it has a lip on it that should help keep the belt on. I'll bet some other forum member can find the link to the posting I am referring to.
Old Jun 16, 2008 | 06:26 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
yes it was
Old Jun 16, 2008 | 06:27 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
Yes that is the belt tensioner part i believe
not the ac tensioner
thanks for the tip tho
To Need Quick Assistance Please.
