Headlights? Sometimes yes sometimes no
Old Jun 14, 2008 | 08:29 PM
nickolbag's Avatar
nickolbag
Default Headlights? Sometimes yes sometimes no
So my headlights will come on......sometimes. I am assuming step one is check grounds? Where and what to clean them with?
Old Jun 14, 2008 | 11:14 PM
ruffian's Avatar
ruffian
Me toooo. Seems to happen mostly if I drive around with parking lights on for any amount of time. Then it gets dark and try for headlights, nada. Pull off to the side of the road, shut er down and restart, then lights come up and on. Very odd.
bob
Old Jun 15, 2008 | 07:57 AM
ronwc's Avatar
ronwc
Check to make sure your battery connections are clean and tight -
Old Jun 15, 2008 | 11:00 AM
nickolbag's Avatar
nickolbag
bob
Exactly. I had to turn all the lights of for a few miles and then they finally came on again.
Will check it out. Thanks.
Old Jun 15, 2008 | 04:22 PM
kg54trains's Avatar
kg54trains
If the lights do not operate at all and there is no high pitch noise on the attempt you will need to check the voltage to your headlight motors. This could be a battery related issue or a control modual that is on the passenger side just above the headlight in the engine compartment. I have repaired the headlight gear to the drivers side and how after a few months this headlight has no sign or sound of activity. I am trying to run down my options without replacing parts that are not the problem.
Good luck.
Old Jun 15, 2008 | 04:48 PM
DeeGee's Avatar
DeeGee
If your headlamps are raising but you're not getting low or high beam, my guess is its probably the multi function switch on its way out. Do the lights come on if you recycle firmly a few times? Try squirting some electronics cleaner in the switch as a start. It may help.
Old Jun 21, 2008 | 04:13 PM
neokorros's Avatar
neokorros
where is the multi-function switch?
Old Jun 21, 2008 | 04:17 PM
DeeGee's Avatar
DeeGee
The headlight switch on the stalk on the left side of the steering wheel
Old Jun 21, 2008 | 09:18 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
If they are coming on (both) but not rising, then its the headlamp controller on the right forward frame rail.
To Headlights? Sometimes yes sometimes no
