Need help and advice with abs problem,Please
I took the car ( a 2002,A4 ) to a local Chevrolet dealership where they ran a diagnostic check on it and determined that it was an internal fault in the EBCM. They wanted $1800.00 to replace it.
I came home and did a search on here and found all the great information about cleaning the grounds.I checked the grounds on both sides of the engine compartment, took them apart and they were clean. I scraped the paint off of the frame where they connect and put them back on. I disconnected the plug to the EBCM and blew it out with air.The car is kept in my shop with a de-humidifier running so everything was clean and dry.
Well, none of that helped. The lights still came on the next time I drove the car.
OK,So I read on here about absfixer. I sent Brandon an e-mail about the problem I was having and the codes it was showing and asked if he thought he could fix it. He replied back that those were not the typical codes that he repairs but he would look at it if I wanted him to.
I sent the module to him and he repaired it and sent it back. I put it back on and went for a test drive. I didn't get two miles before the abs/traction control lights came on. It is showing code C1233H. I'm sure the other codes will reappear as I drive the car more. I read on here where the wheel speed sensors rarely go bad.
Does anyone have any ideas or advice on what I should do now?..Thanks
Bill
Your going to need to find a male electrical pin the same size as the one in the connector that plugs into the female pin that your testing. Insert the male pin into female pin and see if it has the correct tension. If you have to FORCE it in and force it out,,,,,your all set!
Remember,,when you turn the ignition ON,,,it resets all the EBTCM Disgnostics and starts the diagnostic test over. If you have a speed sensor problem, it will take a few seconds or longer before the system detects a fault.
BC
Changed that and HEAVEN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!
