Reduced Power, Engine And Abs Light
Old Jun 17, 2008 | 12:26 PM
zo6fever's Avatar
zo6fever
Default Reduced Power, Engine And Abs Light
When Im in 3rd gear and i floor it the reduced power comes up on the display. Does this happen when its on traction control, comp mode, or when abs is off, can't really tell. But its pretty embarrising when your racing someone. Checked my grounds and they seem to be ok. How do I get rid of this once and for all.
Old Jun 17, 2008 | 12:36 PM
BlackZ06's Avatar
BlackZ06
You need to display your DTC data. If you don't know how to do it go here ....
https://www.corvetteforum.com/techti...D=26&TopicID=1
When the AUTOMATIC display completes it will enter MANUAL mode. In that mode display and write down what codes you have.
A code looks like this ...... P 1234 C
The first letter will be either a P, B, C, or U ..... indicating which system the code is for.
The following 4 numbers are the code
The last letter will be a C or an H (sometimes both).
Post the ENTIRE code, and list all the codes found.
