FAST 90 / LS2 TB question ??
Old Jun 17, 2008 | 11:42 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Default FAST 90 / LS2 TB question ??
I set everything in place today while I am waiting on my shorter valley cover bolts and noticed that when I put the air intake on the LS2 throttle body, the actual plastic tunnel port that the air flows through sticks up way higher than it did with the LS1 throttle body. Is it because everything isnt bolted down or does it really stick up higher.
Also, I have the Nitro Daves 90mm nitrous plate between the TB and the FAST intake.
Old Jun 18, 2008 | 10:53 AM
Corvette-Chris
St. Jude Donor '08
Anyone?
Old Jun 18, 2008 | 11:01 AM
NassyVette's Avatar
NassyVette
Originally Posted by Corvette-Chris
Anyone?
Old Jun 18, 2008 | 11:04 AM
AFBombdude's Avatar
AFBombdude
You may have to cut some off of your silicone hoses, if that's what you have. I had to take about an inch off of one of mine.
Old Jun 18, 2008 | 12:09 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
pics??
Old Jun 18, 2008 | 12:37 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
I have noticed that mine sits a little higher above the radiator, but nothing the keeps the hood from closing.
Old Jun 18, 2008 | 04:54 PM
Corvette-Chris
St. Jude Donor '08
Originally Posted by Ikester
pics??
Ill try to get one up tonight
Mine definanly looks like the hood isnt gonna close
Old Jun 18, 2008 | 08:22 PM
vettenuts's Avatar
vettenuts
You need to bend down the forward coolant cross-over tube, have you done that? The intake will sit on top of it and not go down otherwise. Make sure you don' have any interference there.
Old Jun 18, 2008 | 09:46 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The FAST 90 positions the TB to point upward slightly. I noticed it on mine also. I loosened up ALL the hose clamps and pressed DOWNWARD on the plactic air bridge and coupler and while it was being held DOWN,,,I tightened ALL the hose clamps and it helped put the coupler, bridge and air box in a position that minamizes any interfearance.
Old Jun 18, 2008 | 11:41 PM
Corvette-Chris
St. Jude Donor '08
No I havent done that....Could I just tap it with a rubber mallet and bend it down?
Ok Thanks Bill, Ill try that too
Old Jun 19, 2008 | 10:38 AM
vettenuts's Avatar
vettenuts
Yes, it will bend easily. Just tapp it lightly, but make sure you account for the distance to compress the gaskets when you install and watch this area when you tighten it down to make sure you still clear.
To FAST 90 / LS2 TB question ??
