Coolant Tank
Old Jun 20, 2008 | 06:51 PM
jaxvet's Avatar
jaxvet
Default Coolant Tank
I bought coolant/washer tanks used off a forum member, & I think they are off a 99 C5, so that I could paint & then just swap tanks out.
Is the 99 tank going to work on my 2001 C5? Are there differences that I wasn't aware of? Will I just be able to swap them & it will work properly? Any info appreciated.
Jack
Old Jun 20, 2008 | 06:57 PM
BlackZ06's Avatar
BlackZ06
The reservoir through 1999 has a coolant level sensor built into it. The later cars don't have the sensor. That's the only differrence. Just tuck the wiring for the sensor out of the way since you won't have matching wiring for it.
Old Jun 20, 2008 | 07:34 PM
jaxvet's Avatar
jaxvet
Thanks much for the response, another worry put to rest.
To Coolant Tank
