I have added the a couple of pictures of a quick, home made slave to master coupler disconnect tool. I did a search, on this site, and found no visual aids for this. The actual tool one would use is identified as p/n J-36221 by GM. I made one from a Craftsman paint/gasket scraper by cutting and grinding a notch which is 5/8 inch wide and 5/8 inch or so deep; originally the scraper is 1/16th inch thick (which works great). If you want to duplicate this, ensure you are a little smaller or inside of 5/8th inch as it needs to be close/tight. Once you have this, you press the white plastic edges of the coupler down and relax, don't force it; and it will come apart. Takes only a couple seconds. Hope this helps some of you.
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
I have the proper tool and gave up after a half hour or so. Then I tried cutting the hose with snips. Then broke out the Dremel with a cut off wheel and that solved all my problems, but I was replacing everything and didn't care about it. Once off the car I played with the tool and it did work but still wasn't easy.
So my advice to anyone doing a clutch job and planning on replacing everything, screw the tool and cut the hose. Have a few rags handy cause it will leak some fluid.
Thats what I did, but i had a good pair of dikes - and just nipped through it. Took a few cuts though, and thankfully didn't leak much fluid (we turkey basted the master too)
Thanks for the ideas on the tool! I'm throwing a new clutch in shortly, and this may save me some hassle...
Good to see your tool worked. I made one that didn't and ended up using two screwdrivers. Once you understand how to disassemble the joint it is a little easier. Maybe I will try this tool next time, which I hope is a looooong time from now.
I don't want to belabor this; I wanted to show that such a tool will work to the many that seem to have problems. In many instances, cutting the line may not be a practical solution, and why do it if you don't have to.
St. Jude Donor '13
I forgot to add your tool is cool. Saves the cost of buying one. Your post just brought up bad memories of what I went through and figured I'd toss in my fix. Didn't mean to hijack your thread.
