Damn memory seating!!!
Old Jun 22, 2008 | 10:45 AM
CharlieB1979's Avatar
CharlieB1979
Default Damn memory seating!!!
I have no idea why...but sometimes (most of the time) in order for me to get my seat to where it's supposed to be, I haev to push the memory button several times...it slowly nudges itself up with every push, closer and closer to where it's supposed to be...then sometimes, when I get back into my car, the seat will be all the way forward...!?
Help!!!
Old Jun 22, 2008 | 11:23 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Help!!!
Do you always use the same key fob ? They are numbered 1 & 2 and remember the settings.
Old Jun 22, 2008 | 12:03 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Clean the connector pins at the seat to car interface area under the seat.
Old Jun 22, 2008 | 12:17 PM
CharlieB1979
Yes, I use the same FOB over and over. I know they have their own individual settings.
Clean..the wha??
Old Jun 22, 2008 | 12:34 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I was just thinking the same thing!!!
Check and post your DTCs . If any are set for the memory or If one of your position sensors for the seat isn't working correctly,,it could effect the memory.
Heres the calibration procedure out of the service manual:
Memory Seat Calibration Procedure
The memory seat module uses position sensor inputs to establish soft stop locations for the adjuster motors several millimeters ahead of the physical limits of the adjuster assembly. After replacing a memory seat module or adjuster components, it may be necessary to reset the adjuster motor soft stop locations. When the repair procedure has been completed, operate the seat adjuster switch in every direction until the seat adjuster reaches its mechanical hard stop by repeatedly pressing and releasing the switch as necessary.
Run your seat through the FULL ranges of it adjustability to make sure it working correctly. Once you complete that, get BOTH or all three if you have three set to function and (for the test) set the memory for each fob that you use to lock and unlock to the same settings. Once you are certain its not a FOB related issue, go ahead and set the other FOBs to driver preferred settings.
BC
Old Jun 22, 2008 | 01:17 PM
2003z06vette's Avatar
2003z06vette
I've got the same problem except mine also sometimes won't go back at all when I take the key out. And yes, I do have Easy Entry turned on. I've got no codes and have cleaned it. Maybe it's just going bad and hasn't set off any codes yet?
Old Jun 22, 2008 | 09:20 PM
CharlieB1979
I'm having the same problem as 2003z. Basically the same thing happening for me as for him.
Old Jun 22, 2008 | 10:28 PM
Zo Sex's Avatar
Zo Sex
i have been having the same problem the past few weeks, its weird when i lock the door sometimes and unlock to get in the seat moves all the way foward and i have to keep pressing my #1 mem to move it back. just yesterday i started the car and it went into reduced engine power when i did it and threw a ton of door codes seat codes pcm codes!
Old Jun 22, 2008 | 10:42 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Ah,,,,Zo SEX! Been there had that exact issue. It was a shorted door wiring harness. Remove the rubber accordion tube and look for bare wires.
Thats what caused Mine
BC
Old Jun 22, 2008 | 11:07 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
I have no idea why...but sometimes (most of the time) in order for me to get my seat to where it's supposed to be, I haev to push the memory button several times...it slowly nudges itself up with every push, closer and closer to where it's supposed to be..!?
Help!!!
i have been having the same issue lately. i have the easy entry turned off and still when i lock the car, the seat moves all the way back. then i have to inch it back to where i want it.
Old Jun 23, 2008 | 07:41 AM
gray-c5's Avatar
gray-c5
St. Jude Donor '08
Default Mine too
Mine does not always work correctly either. Guess this is a common problem.
To Damn memory seating!!!
