1984 corvette with LS6
The Clutch is NOT happy at all and slips at anything greater than 400 ft/lbs straight across the RPM band! So,,,I'm VERY sure there is a LOT more in her than it was able to do on the dyno with a bad clutch!
If you want stock driveability and lots more HP,,,add a supercharger with the current engine set up! That will put you close to 600 HP.
I use to own an 85 and it was basically stock. I really don't know what weak links there are in the drive train. It would be very wise to address those too!
Were you able to run duel exhaust or did you have to funnel the exhaust through that single cat and single mid pipe???
Thats a limiting factor. At least get 3" pipe set up if you have to keep that single pipe.
Headers will be a bit of a headache as well as they are designed to clear the C5/C6 - and there might be things in the way on a C4.
Give us a call if you want a quote on a heads/cam package.
Good luck.
Stephen
281 464 2800
They went with my Whiplash cam - and in that light car, they told me they felt like they were taking off when the cam came into powerband!!!!
Good luck
