cranks but will not start
Old Jun 23, 2008 | 02:50 PM
saco's Avatar
saco
3rd Gear
Default cranks but will not start
My C5 Cranks But Will Not Start. This Happened After The Alarm Went Off By Itself. Can Anyone Help Me ?
Old Jun 23, 2008 | 02:56 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
First off,,,what year is the car,,,does it have any CURRENT DTCs and what is the ststus of the "SECURITY LIGHT" on the IPC?
Old Jun 23, 2008 | 03:01 PM
saco's Avatar
saco
3rd Gear
This Is A 98. This Just Happened. Everything Else Works.
Yesterday The Headlights Would Come On But Not Raise. Then They Started Working.
Old Jun 23, 2008 | 03:04 PM
saco's Avatar
saco
3rd Gear
I Do Not Know What A DTC Or Icp Is,
Old Jun 23, 2008 | 03:12 PM
wildbadbill's Avatar
wildbadbill
ICP-instrument panel cluster
DTC-malfunction codes that you can display on the DIC (driver info center) using the special sequence (on-board computers tell you what went wrong)
Old Jun 23, 2008 | 04:21 PM
BlackZ06's Avatar
BlackZ06
To display your DTC data go here ....
https://www.corvetteforum.com/techti...D=26&TopicID=1
When the AUTOMATIC display completes it will enter MANUAL mode. In that mode display and write down what codes you have.
A code looks like this ...... P 1234 C
The first letter will be either a P, B, C, or U ..... indicating which system the code is for.
The following 4 numbers are the code
The last letter will be a C or an H (sometimes both).
Post the ENTIRE code (as in the example ..... P1234C), and list ALL the codes found.
Your IPC is the Instrument Panel Cluster .... your gauges. There is a SECURITY warning lamp in the gauges. When you are cranking the engine is the SECURITY lamp on, or blinking ????
To cranks but will not start
