wipers will not shut off
Old Jul 2, 2008 | 06:54 PM
road dog's Avatar
road dog
Default wipers will not shut off
I got into my vette today and started it and my wipers began to work but I could not shut them off any body else have this problem before ?
Old Jul 2, 2008 | 07:15 PM
lloyd's Avatar
lloyd
Default Wipers
Yes John, we have seen this problem. Usually the wiper motor has been sitting in water because the drains are clogged with crud. You will probably have to repace the circuit board in the motor assy. Be sure to check the three drains under the motor before putting it back together. At each oil change we clean out the drain by reaching under the motor and squeezing the udders.
Lloyd Harvey
Corvette Care, Inc
Columbus, OH
614-471-3331
Old Jul 3, 2008 | 06:49 AM
road dog's Avatar
road dog
Thanks Lloyed some one told me that the switch had gone bad but now that you menyion it we have had a good amount of rain here lately.
now I just got to find the wiper motor location and the board that needs to be changed . I'm getting tied of pulling the fuse and replacing
it when it starts raining lloyed your the chief
Old Jul 7, 2008 | 10:05 PM
ChitownbluZ06's Avatar
ChitownbluZ06
Im in the same boat mine are on as well and i just pulled the fuse.. please keem us posted if u fix the problem and how
Old Jul 7, 2008 | 11:55 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Check your UDDERS! Bet ya didnt know you had udders!
Your wiper controller got wet. Sometimes they will dry out.
Reach in hear and unclog em:
BC
Old Jul 9, 2008 | 02:51 PM
George Hollaway's Avatar
George Hollaway
2nd Gear
Default 1998 C5 Same Problem with Wiper Motor
Lloyd Harvey
Corvette Care, Inc
Columbus, OH
614-471-3331
Yes I have the same problem, and was wondering if it is hard to locate the drain plugs (3) on the wiper motor? It rained a lot yesterday and when I turn off wipers they go almost all the way in the finish mode, then hesitates a few seconds, and then try and wipe, but it only wipes about 4 inches,,,this continues until I turn off vehicle. I hope I can find the drains OK.
Old Jul 9, 2008 | 03:23 PM
BigGun's Avatar
BigGun
Lloyd Harvey
Corvette Care, Inc
Columbus, OH
614-471-3331
The udders feel like they are full of crud. Do you just pull them out to clean them, are they easy to get back in?? Thanks, B/G
Old Jul 9, 2008 | 03:49 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Just yank them off the bottom of the well. They pop back in the holes just as easy as they pop out. I check mine everytime I wash the car. ZJust stick your hand in the hole and squeeze them. if there hard, there plugged.
BC
Old Jul 11, 2008 | 02:36 PM
George Hollaway
2nd Gear
Default Malfunctioning Wiper Motor
I have cleaned out the utters which had a lot of debris clogging them up.... in hopes of allowing the components in the Wiper Motor to air dry. It has been a couple of days, and this morning on the way to work the wipers came on all by themselves, only for one swipe across the windshield.
How many days should I anticipate it taking to dry the cuircuit board out, in hopes this wiper issue to cease?
I hope the board hasn't shorted out!
Is there anything else I should try at this point?
Mike
Chesapeake VA
michah14@yahoo.com
Old Jul 11, 2008 | 07:06 PM
JH's Avatar
JH
It's anybody's CWAG as to when the circuit board may dry out. Hope it does!
Good luck!
To wipers will not shut off
