what cam?????????
Old Jul 7, 2008 | 08:08 PM
rockit98vette's Avatar
rockit98vette
Default what cam?????????
cam suggestions?
i have a 98, ls6 intake, lg lt streets, bnb bullets,, handported stock heads w valvejob, vararam intake, i drive the car abit not a daily driver but i drive it a hundred miles or so at a time, and just seein what anyone suggests, company wise, thunder, lg, lingenfelter, etc and cuts im kinda thinkin, mid 220's .560's and about a 114? right dirrection? or go bigger? thanks
Old Jul 7, 2008 | 08:20 PM
motogib1's Avatar
motogib1
Old Jul 7, 2008 | 09:08 PM
vettenuts's Avatar
vettenuts
Mid 220's on a 114 will make a nice streetable cam. All depends on what you are looking for. A lot seem to over-cam.
Old Jul 7, 2008 | 09:10 PM
kingsey's Avatar
kingsey
224R from texas speed.
Perfect
Old Jul 7, 2008 | 09:21 PM
Pro Street's Avatar
Pro Street
I have the Texas Speed 224R (224/224 581/581 114 ) nice cam!
Old Jul 7, 2008 | 10:30 PM
BANDIT HPT's Avatar
BANDIT HPT
Any cam with a **** star name j/k
Old Jul 7, 2008 | 10:41 PM
QUICKSLVR's Avatar
QUICKSLVR
Default G5x3 / 114
big cam but it RIPS. Drivability ......we drive ours every day for 3 years
no problems. Now they have version 2 ........
Lg cams are track tested and Comp Cams grinds them. Do a search, lots of ls6 motors make 430 plus just with cam kit, headers.Stock heads. Still lovin mine.
Old Jul 7, 2008 | 10:43 PM
black98c5's Avatar
black98c5
I have the G5X3 112lsa on a A4 to boot and it's awesome. Sounds like something like a 224/228 112lsa is what your looking for though. You'll get lope and good power across the power band.
Old Jul 8, 2008 | 12:37 AM
rockit98vette
Default thanks for the info guys
think i should go with straight from comp ?or,lg, or texas speed, ?i have heard good with tsp on ls1 tech like what u responders have said, thanks alot
Old Jul 8, 2008 | 01:33 AM
rockit98vette
Default think the
lg g5x1 is a good cam? and think i need to replace the lifters also?
Old Jul 8, 2008 | 01:47 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
get my cam
Old Jul 8, 2008 | 01:59 PM
BANDIT HPT's Avatar
BANDIT HPT
A G5X3 on a 114 has a nice lope to it.
Old Jul 8, 2008 | 10:37 PM
Johnny Hardcore's Avatar
Johnny Hardcore
I currently run a "Cam Motion" custom ground 232/236/114 with .600 lift in my 99 MN6. The driveability is fine. A little feathering of the throttle is sometimes needed when coming to a stop. My wife and I drive from NYC to NH every two months and the car performs and drives very well. I'm even getting around 23 mpg's, with a little horse play on the Mass Pike.
I have a custom ground cam 228/228/112 .5695 lift that I was running in the car and was going to reuse with the new build but decided to go bigger. This cam drove like stock in the car FYI. The 112 gets up and goes a bit lower than the 114 but I built the car for both 1/4 and road racing this time around.
If your interested in the cam, I have it here at the house somewhere in a box, with all the stats from the machine shop. It's been chemically cleaned and spec was done by "Cam Motion" in Baton Rouge LA, and its ready for install.I also have the dyno sheet on hand. With the 228/228/112, the car made 390rwhp with 376rwtq, with BBk shorties and Stage 1 LS1 heads. I'll sell it for $175 plus shipping.
PM me if your interested.
Old Jul 10, 2008 | 10:55 AM
rockit98vette
Default thanks bro
ill think about that one but i have maybe decided to go with a 580 or so
Old Jul 10, 2008 | 11:28 PM
jedblanks's Avatar
jedblanks
FWIW, I was in the same boat as you and I went with a 228/232 cam with 580ish lift, 113 LSA. I knew it was on the edge of "streetable" but I was afraid of going too small at the time. Based on what everyone was saying at the time, bigger was better and many had wished they'd gone bigger. My cam is streetable, but is no sleeper.
If I had it to do again I'd probably go 220 or 224 114-115 LSA range to keep the more stock driveability and lower powerband.
I do most of my driving between 1000 and 3000 rpms, with a few spirited runs to 5500 thrown in. The powerband of my cam is 2500+, and really doesn't run too smooth below 1500.
I'd have probably given up 10-20 peak hp by going smaller. It's not enough to make me want to do it over, but if I knew what I know now, I'd have gone a smidge smaller.
To what cam?????????
