Thread Size Help
Old Jul 7, 2008 | 09:52 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Thread Size Help
I am working on installing an LS6 in my 70. So far things are going pretty good and I should have a pretty nice little hot rod when all is said and done. I have another quick question and I cannot come up with a definitive answer.
There is a hole in the head that is just behind the last manifold bolt. It is not the one farthest left in this picture but the 2nd one from the left. This hole is plugged by a socket head bolt. What is the thread pitch on this hole?
Any help is greatly appreciated.
Old Jul 7, 2008 | 09:53 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Im not sure the thread size but I know if you leave it unplugged, coolant will **** everywhere......ask me how I know lol
Old Jul 7, 2008 | 10:00 PM
Eddie 70's Avatar
Eddie 70
I have it plugged right now but I am wanting to put a sending unit so I can use the stock gauges in my 70 vette. If I can cut my sending unit down to that size, I am golden and will have a functioning temp gauge.
Old Jul 7, 2008 | 10:08 PM
Eddie 70's Avatar
Eddie 70
One place I read that that thread size is 12X1.5 and another says it is 14X1.5. I just need confirmation that it is either one or the other.
Old Jul 8, 2008 | 05:30 AM
vettenuts's Avatar
vettenuts
I have the plug part number at home and can look up the thread. I can't see the picture at work, but if it is the one ?I think you are describing the thread is the same as the coolant temperature sensor.
Old Jul 8, 2008 | 06:37 AM
Eddie 70's Avatar
Eddie 70
It is the same as the coolant temp sensor. On the drivers side, the coolant temp sensor is in the head. On the passengers side rear, it is plugged. I was going to try and cut a stock 1970 temp sensor to match this thread and use it in the hole. That is, if there is enough material to make it work. I am going to stop by Ace Hardware this evening on the way home and pick up a couple of bolts and see which one fits. I will post back with what I find.
Old Jul 8, 2008 | 12:29 PM
hotwheels57's Avatar
hotwheels57
...ahhh...bolts and pipe plugs are usually different thread/pitch. You sure don't want to mess up the aluminum heads!
Why don't you just remove it and take it to your favorite automotive/hardware store and find a reducer (OD to fit the head and ID to fit the oem sensor). You might not even have to cut down your oem sensor.
Old Jul 8, 2008 | 09:47 PM
Eddie 70's Avatar
Eddie 70
The thread size in the head is 12X1.5. I picked up two bolts at Ace hardware today. 12X1.5 and 12X1.2???, those suckers are $2.76 each!!! They are not even the high grade stuff either. Needless to say, they will be going back to Ace tomorrow with the receipt. DAYUM!!!!
I am going to try a little home grown engineering and see if I can get the stock sensor turned down and put some threads on it to match. I have a few machinist buddies that might have a little free time on their hands tomorrow. Maybe I can take advantage of some of that free time.
Old Jul 9, 2008 | 06:02 AM
vettenuts's Avatar
vettenuts
The required plug is cheap, why not just buy that?
Old Jul 13, 2008 | 12:11 PM
thetorch's Avatar
thetorch
Here are the dimensions on the coolant plug.
I don't know what the thread size of your sending unit is, but Autometer makes an adapter: http://www.autometer.com/cat_accesso...il.aspx?vid=61
Old Jul 13, 2008 | 05:40 PM
Eddie 70's Avatar
Eddie 70
I had it milled to make it 12mm and it works like a champ. I put teflon tape on the thread and an aluminum crush washer for a motorcycle drain plug. It should not leak and make good contact with the head for a good ground.
Here is my solution.
Old Jul 13, 2008 | 05:58 PM
hotwheels57
That's a nice solution to your problem. I always ended up using reducers which didn't always look good.
If you start experiencing fluctuations in your coolant readings, it might be the TEFLON tape. Brass pipe thread fittings usually don't need sealant as they're tapered. I liked using a sealant as well and found TEFLON tape didn't always bring consistent readings due to poor grounding of the electric senders. Once I switched to TEFLON based paste, they were fine.
Old Jul 13, 2008 | 06:43 PM
thetorch's Avatar
thetorch
To Thread Size Help
