GM Parts Gurus...
Dec 28, 2001 | 12:14 AM
GM Parts Gurus...
Wanting to know how muc LS6 Heads and the Hot Cam Cost, I ran a search on "LS6" at
http://www.paceparts.com.
For the heads it returned the following...
PN 12560801
Gen III 2001 LS6 Cylinder Head, 63CC Combustion Chamber head with D-shaped exhaust ports.
$661/Each Bare
PN 12564825
2002 LS6 Cylinder Head: <<No Description>>
$614/Each Bare
If I want the LS6 heads that come on Z06 Vettes, which is it?
[Modified by Closer_2001, 5:51 PM 1/1/2002]
Dec 31, 2001 | 01:19 AM
Re: GM Parts Gurus... (Closer_2001)
ttt
Dec 31, 2001 | 01:28 AM
pace is good. You may want to try this guy:
Shaun (valvegod@aol.com)
(248) 276-0483
(248) 496-7887
he probably can get you the info and parts you want for great prices.
Dec 31, 2001 | 03:46 PM
6th Gear
that is correct there are 2 different heads 1 for a '01 another for '02
Jay
Dec 31, 2001 | 04:11 PM
Re: GM Parts Gurus... (Jay Fisher)
I believe the bare heads for 2001 and 2002 should be the same. But the assembled head would be different due to the differance in spring rate and the lighter-weight, sodium-filled valves.
Someone can correct me if i am wrong.
Jan 1, 2002 | 07:51 PM
Re: GM Parts Gurus... (SoCal C5)
Pace is showing different part numbers and prices for the 01 and 02 LS6 heads. The 02 heads are less.
Jan 1, 2002 | 08:25 PM
'01 & '02 LS6 heads are identical.......the only difference between the two are the springs and longer sodium/potassium filled valve stems.
Jan 1, 2002 | 08:28 PM
Re: GM Parts Gurus... (97C5ENVY)
Sorry, but, Why are there 2 part numbers for bare LS6 castings then? :confused:
I'm not talking about the valves and springs.
Jan 1, 2002 | 08:42 PM
Probably due to the valve seats since the '02 has different springs, because past that everything else is identical.
FYI:
http://www.gmpartsdirect.com has the '02 heads for $534.60 each and '01 heads for $620.78 each.
