LS7 in a C5?
Old Jul 18, 2008 | 07:39 AM
M1Cruiser's Avatar
M1Cruiser
Default LS7 in a C5?
Other than the exhaust and installing a dry sump or converting to a wet sump, what issues need to be addressed when putting an LS7 in a C5.
Old Jul 18, 2008 | 08:27 AM
AU N EGL's Avatar
AU N EGL
putting on a 24 tooth wheel so the C5 computer can be used
Old Jul 18, 2008 | 09:58 AM
99C5JA1's Avatar
99C5JA1
Extending the knock sensor and cam position sensor harnesses.
Old Jul 18, 2008 | 11:52 AM
LoneStarFRC's Avatar
LoneStarFRC
That's the biggest issue overall I think. That's one of the reasons I chose to go with a Darton sleeved 427 LS2 block with good stuff inside. The rest of the LS7 stuff just bolts right on.
Old Jul 18, 2008 | 03:26 PM
M1Cruiser's Avatar
M1Cruiser
LoneStarFRC - It sounds like it'd be a lot less expensive and less hassle to build a sleeved motor than using an LS7 and you'd have lot more power. Scoggin Dickey had a L92 427 motor they built, It was part of their El Toro Grande series, for about $8,000 and it had a well over 600 HP at the flywheel. Now you've got me thinking again.
Old Jul 18, 2008 | 06:16 PM
LoneStarFRC
That's what I did. It's a Darton sleeved LS2 block with 4" stroke and 4.125" bore. My heads and intake w/injectors are LS7. I LIKE those big beer-can sized intakes. I also chose to use Comp springs w/TI retainers and stainless valves from Rev instead of the uber priced Titanium pieces. Even my old LS1 oil pan bolted right up.
The only other matter that no one has mentioned so far that I can think of is in the area of the headers. Regardless of block choice, etc, the LS7 heads have "D" ports on the exhaust side and so I had to specify my Kooks headers to come with an LS7 compatible exhaust flanges. You'll just need to specify year, AND transmission for your C5 and then of course ask for an LS7 flange.
It cost me about $100 extra, but they bolted right up and seal perfectly with no issues.
Old Jul 18, 2008 | 06:56 PM
JVetthead's Avatar
JVetthead
I just had an LS7 block 427 built. We used a callies crank with the 24x ring and an ls1 style snout so we could use an ls1-2 wet sump pump and my old ballancer and pan. You do not have to use the LS7 dry sump although I will probably go aftermarket dry sump in the future
Old Jul 21, 2008 | 04:03 PM
yyzmsp's Avatar
yyzmsp
From: maple grove and North Port fl mn and now florida
you will also need to adapt the throttle body electrical plug as i presume you will go with a larger t/b.
Old Jul 21, 2008 | 04:37 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
I have ECS build LS7 in my C5 - 565RWHP / 540RWTQ good numbers especially since we kept it down due to the fact that my car is a road race car.
I picked the LS7 over other applications because I wanted the Dry Sump which is beneficial for RR.
You can read about and see pictures of the install here
http://www.ecsracing.com/ecsracing/f...splay.php?f=77
Old Jul 21, 2008 | 08:02 PM
LoneStarFRC
What was your cam choice? What does she idle at?
Old Jul 21, 2008 | 10:49 PM
C5 LS7's Avatar
C5 LS7
To LS7 in a C5?
