Pfadt Trans Brace Install
Old Jul 25, 2008 | 03:54 PM
Mike94ZLT1's Avatar
Mike94ZLT1
I think I just found something else I never knew I couldn't live without! Chip, how long is that price good for? My birthday is in another 2 weeks and I will drop some hints, but if I don't get it I will for sure be ordering one!
Is it available in any other colors by chance?
Old Jul 25, 2008 | 04:24 PM
JoshS's Avatar
0JoshS
Former Vendor
St. Jude Donor '08
Autocross & Roadrace Forum Sponsor
Default Pfadt Transmission Mount
Originally Posted by vettenuts
Thanks, I kind of figured that but it wasn't immediately apparent in the photo on your web site. A view from an angle would be beneficial.
Can you weigh in on the question about benefits with the DTE brace?
Also, can the differential brace be stand-alone or is the engine mount required to take advantage of this setup?
The Pfadt Transmission Mount and the DTE brace are focused on two different problems. The DTE brace is focused on strengthening the transmission and differential. The Pfadt Transmission mount is focused on transferring the loads from the transmission and differential to the sub-frame.
The Pfadt Engine and Transmission mounts can be used alone or together. Both the engine and transmission see a substantial amount of movement. So we recommend replacing both engine and transmission mounts.
Get creative on dropping hints. Maybe change your computers home page to this
May not be very subtle though!
As far as the color they only come in Pfadt Orange.
Old Jul 25, 2008 | 05:17 PM
vsocks1's Avatar
vsocks1
[QUOTE=JoshS;1566452540]The Pfadt Engine and Transmission mounts can be used alone or together. Both the engine and transmission see a substantial amount of movement. So we recommend replacing both engine and transmission mounts.
How hard is the engine mount install?....if you are not doing engine replacement!
Old Jul 25, 2008 | 05:23 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
[QUOTE=vsocks1;1566453270]
It's a bit of work, but not to bad
I have a PDF if you want it...
Peace
Chip
__________________
..................Click for
Old Jul 25, 2008 | 05:27 PM
vettenuts's Avatar
vettenuts
Did I miss it? Is there a special price?
Old Jul 25, 2008 | 05:28 PM
CCA Corvette Parts
Not that I am aware of
Peace
Chip
Old Jul 25, 2008 | 08:39 PM
vettenuts's Avatar
vettenuts
Chip,
Any way you can post up the installation instructions? I looked on the Pfadt web site, but these were one that I didn't see.
Old Jul 25, 2008 | 11:22 PM
CCA Corvette Parts
Chip,
For which one
Peace
Chip
Old Jul 25, 2008 | 11:53 PM
NemesisC5's Avatar
NemesisC5
That T-Brace is just one bad azzzz unit
Old Jul 26, 2008 | 07:26 AM
vsocks1's Avatar
vsocks1
[QUOTE=Willfulone;1566453336]
Peace
Chip
How about the engine mount install pdf? Thanks!
Old Jul 26, 2008 | 07:44 AM
vettenuts's Avatar
vettenuts
Originally Posted by Willfulone
For which one
Peace
Chip
Differential brace, but actually the engine one would be good too.
Old Jul 26, 2008 | 01:16 PM
jdmvette's Avatar
jdmvette
Night Owl for life
interesting...
Old Jul 26, 2008 | 04:31 PM
  #33
WKMCD's Avatar
WKMCD
Oh Chip, old buddy, old friend....You know I need one of these but just didn't think it would take this long to tell you to get me one...
I think I'm going to need one bad with the new setup.
BTW: Do you offer installation.
Old Jul 27, 2008 | 10:08 AM
  #34
JVetthead's Avatar
JVetthead
Will this work with rear mounted ABS unit or diff cooler lines?
Old Jul 27, 2008 | 10:57 AM
  #35
CCA Corvette Parts
I'll add it to your tab...
I guess I'll have to, it's all upside down work
Peace
Chip
Old Jul 27, 2008 | 11:00 AM
  #36
CCA Corvette Parts
Not an issue on the ABS
I did not need to re-route any lines, but I did have to manipulate the lines a little to get them to pass under the brace arms.
The instructions read "re-route" if needed...
Peace
Chip
Old Jul 27, 2008 | 01:29 PM
  #37
ericdwong's Avatar
ericdwong
Dang.. I haven't bought a car mod in a while but this one really stands out. Gotta do some calculations
To Pfadt Trans Brace Install
Old Jul 29, 2008 | 09:29 AM
  #38
CCA Corvette Parts
Don't you just hate that...
Peace
Chip
Old Aug 1, 2008 | 09:30 PM
  #39
thekid96's Avatar
thekid96
Got mine in and put some miles on it. "Clutch chatter" and wheel hop are gone, amen. Only potential downside is more noticeable transmission of drivetrain vibration to the car and shifter, but hey, if you are installing one of these ride quality probably isn't number one on your list.
Old Aug 1, 2008 | 09:44 PM
  #40
CCA Corvette Parts
Awesome Ryan, that was fast
How was the install?
What kind of shifter do you have?
Peace
Chip
