Pfadt Trans Brace Install
Old Aug 1, 2008 | 09:52 PM
  #41
thekid96's Avatar
thekid96
Originally Posted by Willfulone
Awesome Ryan, that was fast
How was the install?
What kind of shifter do you have?
Peace
Chip
Install went smooth. I just switched from a B&M to an MGW shifter, love it. The brace is some of the best $ I have spent on my car.
Old Aug 1, 2008 | 10:43 PM
  #42
jdmvette's Avatar
jdmvette
Night Owl for life
damn i'm starting to want one of these things...i hate it when that happens.
chip, what does it cost to ship one of these things?
Old Aug 2, 2008 | 09:46 PM
  #43
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
$20 in the US Jason
Peace
Chip
__________________
..................Click for
Old Aug 2, 2008 | 09:50 PM
  #44
CCA Corvette Parts
I get some on my MGW but it is different than before.
Before it was more of a bigger "amplitude" vibration.
Now it seems more like a buzz than a vibration.
To me it seems like less...but them again I'm about as sensory dumb as it gets...lol
Peace
Chip
Old Aug 4, 2008 | 09:34 AM
  #45
vsocks1's Avatar
vsocks1
Just an update - Chip was very helpful with any install questions. Great guy!
Chip - your instruction list in this post could be updated slightly. The socket for the poly pad nuts is 14mm. I also believe the socket for the two nuts at the botton of the mount are 18mm.
Pfadt - A future product improvement would be to have some kind of way that pads won't turn when nuts are tightened. It was hard to install the shim on the pads while in position. Pad wanted to turn when nut was tightening.
Good quality product. Installed in my 2003 Z06. I had to install 1 shim with each poly pad. Also had to remove the resonator on the diff. due to interference. Chip verified with Pfadt that it is not needed with the new trans mount. Thanks!
Old Aug 5, 2008 | 01:10 PM
  #46
stlchevy97's Avatar
stlchevy97
just picked one up.
Old Aug 7, 2008 | 09:04 AM
  #47
CCA Corvette Parts
Updated
Peace
Chip
Old Aug 9, 2008 | 08:13 AM
  #48
CCA Corvette Parts
Originally Posted by stlchevy97
just picked one up.
Got it
Peace
Chip
Old Aug 15, 2008 | 03:31 PM
  #49
CCA Corvette Parts
All current orders are shipping Monday...
Peace
Chip
Old Aug 15, 2008 | 04:57 PM
  #50
WKMCD's Avatar
WKMCD
Peace
Chip
Is there anyplace in the Manassas area I can get one of these??
Old Aug 29, 2008 | 05:23 PM
  #51
CCA Corvette Parts
Funny, I have one with your name on it?
Peace
Chip
Old Mar 13, 2013 | 02:46 PM
  #52
162chevy's Avatar
162chevy
Hello all, I just installed this PFADT Trans bracket on my Red 2002 ZO6 and wow what a difference. No "Wheel Hop" no driveline vibration if you decide to roast the tires. Before when I lit the tires up it would shake the entire car and I felt it was all coming apart, this brace has taken all that away, Very Pleased. Installation was not a problem follow the directions, and I had to remove the Vibration Dampner on the drivers side of the rear end/Trans. Easiest was to remove the driver tire for the top bolt and come from under neath to get the bottom bolt. I am so happy with this brace I am going to go ahead and order another one for my Yellow 02 ZO6. Next will be C6 shocks, new sway bars and Heim Joint end links and then off to the motor shop.
