My stock pulley walked off on my 01 Z06 and I want to replace it. I was going to go with a stock size Powerbond, but it seems no one is stocking them.
For those of you who have done 25% UD pulleys, will I see any adverse side effects from actually going UD? Like interior power inconsistency and fluctuations in the lighting and such?
I remember back when I had an fbody I did an ASP pulley and it made the car run a little strange.
I realize I can always add an alternator OD pulley but I was just wondering if I will even need to?
I installed one and everything seems fine. I did get higher than normal coolant temps on the way back from the Cruise In down in BG. The traffic was HORRIBLE and It was 95 @ 300% humidity Once we were moving again all was fine.
From: Arlington Texas, originally from San Angelo, TX
I really like mine.
BC
How much higher was you coolant temp than before? I suspect only a few degrees or so. I installed an Evans high flow water pump at the same time so I am running cooler if anything. No charging problems at all I might add.
