Cleaning and LS6 intake
Old Jul 29, 2008 | 06:39 PM
LoneStarFRC's Avatar
LoneStarFRC
Originally Posted by iced98lx
I'll take a good close look at them then, before deciding they're okay to reinstall. Thanks for all the tips, I'll be spending a lot of time cleaning this one out I can see.. no metal bits, but plenty of oil everywhere.
These gaskets, as well as the throttle-body gasket have a good history of re-usability. Barring any obvious tears, damage, etc it will be pretty safe re-using them. I have in the past with no ill effects.
Don't worry about the foam pieces on the bottom. They are not a critical item. If you can save them fine, but if they get damaged don't worry. If the MAF sensor is still installed, you might want to remove it too before cleaning. Even if it were to be damaged though, you can always swap over your old one.
If you do use Simple Green, the only precaution they usually mention is to not let it dry or sit too long before rinsing. It's safe for most all plastics and there are some brass threaded inserts for fasteners, but I don't see it being a problem on brass.
HTH
Old Jul 29, 2008 | 07:35 PM
fixvet's Avatar
fixvet
I got my 8 O-ring type rubber gaskets at Kragen's.....for about $20 if I remember correctly. They are very durable! Go on the websites of the parts houses. They all have them.
Old Jul 29, 2008 | 07:58 PM
Kamil D.'s Avatar
Kamil D.
HTH
where is the MAF ssensor located?
and how do you disconect the pice in the beck ?
