Best Rear End?????
Old Aug 3, 2008 | 05:03 AM
TKT-MKR's Avatar
TKT-MKR
Default Best Rear End?????
Hey Guys I was thinking about putting in a different rear end for my car sooooooo
I have 2 questions
1) what is the stock rear end gear ratio?
2) what is the best setup to run with a s/c'ed c5 putting down about 450-500hp?
Old Aug 3, 2008 | 11:26 AM
vettenuts's Avatar
vettenuts
DTE, no question. Contact Phil and discuss with him.
Old Aug 3, 2008 | 12:57 PM
1slowFRC's Avatar
1slowFRC
Make sure to get the brace too...best rear end is the one that is not blown!
Old Aug 3, 2008 | 01:01 PM
fdxpilot's Avatar
fdxpilot
I have 2 questions
If you have a manual, 3.42.
If you have an A4, 2.73 or 3.15 if you have the G92 performance axle.
Old Aug 3, 2008 | 03:44 PM
HT1663WB's Avatar
HT1663WB
I currently have the stock 3.42's. I have an appointment at ECS on Thursday to have 4.10's installed so I'll let you know
Old Aug 3, 2008 | 07:47 PM
TKT-MKR's Avatar
TKT-MKR
ht1663wb are you supercharged?
and i dont mean what rear end to get by who i mean what gear ratio should i get. basically i dont want to make 1sy and 2nd gear a waste. i just want to make all the gears the best with the setup i have. i have driven some cars that were s/c'ed and had gearing that wasted the 1st and 2nd gears
btw, i have a 6 speed z06 tranny
Old Aug 3, 2008 | 09:22 PM
HT1663WB's Avatar
HT1663WB
I have a 2000 M6 Coupe. No super charger.
I would say with the M12 and 3.42's you have the perfect set up for your super charger. I also semt you a PM hope it helps.
Old Aug 6, 2008 | 12:27 PM
TKT-MKR's Avatar
TKT-MKR
HT1663wb thanks for the info.
Yeah I have seen some people with the re-inforced rears
as for all,
as for my s/c i am running 10 psi on a maggie s/c
just would like a little more snap out of my car
what would be the best option since 4.10s i would think would be too much. right?
Old Aug 6, 2008 | 05:37 PM
Pumba's Avatar
Pumba
I have 2 questions
In answer to your second question, the best setup is a C6 Z06 carrier, rear crossmember, and rear lower control arms. In addition, you should have the carrier built with a Quaife differential. See pictures belowL
Quaife Differential:
The next best setup is to have your C5 differential built up with a Quaife:
And, never use a MN12 trans. It's gear spacing is poor and its first gear is too low - 2.97:1.
Also, there are other quality places to have a diff built. PM me if you are interested.
Old Aug 6, 2008 | 07:14 PM
TKT-MKR's Avatar
TKT-MKR
well too late i have the z06 c5 (mn12?) tranny now.
so i just want to improve on what i have but not go ***** out.
this car was not meant to be a 100k monster car (even though it is adding up to be that) but more like a good looking performance machine.
so i figure since i already have these things and to get the tranny swapped back it would be more money again....
so what would be the best setup for my moderate upgraded engine to make sure nothing busts and i am always on the road (as best as i can be)
Old Oct 21, 2008 | 07:15 PM
YO-EL's Avatar
YO-EL
Who installs the Quaife?
Old Oct 21, 2008 | 07:55 PM
vsocks1's Avatar
vsocks1
I believe RPM Transmissions does. I think they put together a really good rear end!
Old Oct 21, 2008 | 09:41 PM
02gt350's Avatar
02gt350
x2
Old Oct 21, 2008 | 10:14 PM
DNAST1's Avatar
DNAST1
2025 C8 of the Year Finalist - Modified
2023 C5 of the Year Winner - Modified
2023 Corvette of the Year Finalist (C8) - Modified
2023 Corvette of the Year Finalist (C6) - Modified
2022 C8 of the Year Winner - Modified
2022 C6 of the Year Winner - Modified
I have a RPM diff with 4:10 gears installed by LG Motorsports this summer. I love it! No issues!
Old Oct 21, 2008 | 11:35 PM
black98c5's Avatar
black98c5
RPM built 3:73 Diff here. Very happy with mine.
Old Oct 22, 2008 | 10:45 AM
David426's Avatar
David426
my wife has the best rear end
Old Oct 22, 2008 | 10:52 AM
nickolbag's Avatar
nickolbag
prove it
Old Oct 22, 2008 | 11:09 PM
mellowyellow01vert's Avatar
mellowyellow01vert
Bragger....
To Best Rear End?????
