Change O2 sensors?
The cost of O2 sensors would quickly offset any "savings" from added MPG for a while.
My thinking, if they're not throwing any codes, then they're still in range. You can have them monitored though if you're curious to how the O2's are responding. There are many ways to optimize gas mileage such as: proper tire pressure, driving habits, maintenance, etc. In reality, if gas mileage is a big concern for you, then a V8 anything is not going to serve you well right now.
For you, as mentioned I agree with lucky. When it comes to 02's, don't change them till the check engine light comes on and tells you your now outside your range. The 02's get lazy over time and will trigger the codes and check engine light....but honestly when I changed mine out, I noticed no difference in performance or MPG. My car has always gotten around 25mpg average (combined city and highway). At $60 each for the fronts and $70 each for the rears....this is pretty costly to do just for maintenanace. $260 for sensors! That would make me think, there better be a problem.
The OBD2 system will not detect if the 02's have drifted slightly out of range. Slightly out of range can cause a dramatic loss in gas mileage.
02's like any other precision measuring device should be replaced at regular intervals. The most I recommend putting on a set is 80k, and then they get changed.
I suppose you could chalk it up to an oil company conspiracy, but the automotive sensor guys wouldn't allow that....or would they?
Very confused by this.
* 166 000 km (100,000 mi) Replace the spark plugs. This is an emission control service. Refer to footnote [Dagger].
* Inspect the spark plug wires. This is an emission control service. Refer to footnote [Dagger].
* Change the automatic transmission fluid and filter if the vehicle is mainly driven under one or more of these conditions:
o In heavy traffic where the outside temperature regularly reaches 32°C (90°F) or higher.
o In hilly or mountainous terrain.
o Uses such as high performance operation.
If the vehicle has not been used under any of the severe conditions listed previously and, therefore, has not had the automatic transmission fluid and filter changed, change both the fluid and filter.
Manual transmission fluid does not require change
