[help] turn signal lever replacement
Old Aug 8, 2008 | 03:49 PM
Svelte_C5's Avatar
Svelte_C5
St. Jude Donor '09
Default [help] turn signal lever replacement
Has anyone done this before?
I have the part and it's ready to go in but I would like any advice that might help before I dive in.
Can this be done without removing the steering wheel?
Old Aug 9, 2008 | 06:41 PM
Svelte_C5's Avatar
Svelte_C5
St. Jude Donor '09
Old Aug 10, 2008 | 03:45 AM
rustyguns's Avatar
rustyguns
????????????? anyone ? ttt
Old Aug 10, 2008 | 03:49 AM
DeeGee's Avatar
DeeGee
Heres a link that Alaskanpilot posted up that should help:
http://forums.corvetteforum.com/show....php?t=2032925
Old Aug 10, 2008 | 03:50 PM
Svelte_C5's Avatar
Svelte_C5
St. Jude Donor '09
Awesome! Thanks, that's exactly what I needed...
Old Aug 10, 2008 | 05:11 PM
Stealthy4's Avatar
Stealthy4
St. Jude Donor '06
In step 10 where they remove the 2 torx screws, (just like the link mentions), the top screw is easy but the other is behind the steering wheel. However, if you rotate your steering wheel 90degrees to the left (so the big hole you look through to see the gauges in normal driving positions) so its now at the "9oclock" position, you should be able to get to it with a regular torx screw driver.
Old Aug 11, 2008 | 02:36 PM
Svelte_C5's Avatar
Svelte_C5
St. Jude Donor '09
Yeah it does say to rotate the steering wheel to the left, but not how much, so I was wondering about that, thanks...
To [help] turn signal lever replacement
