Where to buy ZDDT additive for oil?
My local speed shop has some and I would think any decent speed shop would although that’s not confirmed. Its possible I'm just lucky although I doubt it.
Mark
Mark
Why? Alot of off the shelf oils are good to go. Mobil recently re-introduced one of their oils to specificly adress the issue and most of 'high mileage' oils have adequete levels. NAPA sells a Valvoline oil thats good to go as well.
I run redline synthetic in EVERYTHING now and I love it, but my the only place local to me that carried it (Livernois) quit carrying it, so now I have to order it from summit and thats a pain in the ***. So... I was thinking of switching to mobil 1 and putting the additive in there. I think I might just stick with the redline though.
Why do you want to add ZDDP to a roller-cam engine? There's virtually no reason TO do this, and a number of reasons NOT to - including reduction life of O2 sensors and cats.
The ZDDP thing is a flat-tappet (GEN I) issue - ZDDP was reduced to 800 PPM as part of the GF-4 spec specifically as roller cams don't require it. This lead to a ton of failures in flat-tappet cam engines, specifically the flat-tappet roller-cam profiles with high spring pressures like CompCams Xtreme Energy series. These engines require 1400+ PPM ZDDP and need to use a non-GF-4 oil such as the Castrol, Quaker State or Lucas oils made for "older engines".
Bottom line - you don't want to add ZDDP to an LTx or LSx (or even >'87 Vortec) engine.
The ZDDP thing is a flat-tappet (GEN I) issue - ZDDP was reduced to < 800 PPM as part of the GF-4 spec specifically as roller cams don't require it. This lead to a ton of failures in flat-tappet cam engines, specifically the flat-tappet roller-cam profiles with high spring pressures like CompCams Xtreme Energy series. These engines require 1400+ PPM ZDDP.
From the Eastwood site:
ZDDP also alters bearing and journal surface characteristics to prevent metal to metal contact. Under extreme conditions like a high performance motor, ZDDP reduces the tendency of parts to scuff or gall under heavy loads.
I've found that high ZDDP (1400 PPM+) oils are more likely to form sludge in daily driving and more likely to form CC deposits. This is anecdotal, so feel free to call :
Completely agree that it reduces the likelihood of galling when the film breaks down - as can happen with high spring pressures and flat-tappet cams. Roller cams/lifters can't really gall unless the roller stops...and if this happens, again - the lube won't matter.
For a (real) racing engine - maybe - as they run close to the edge and do have situations where the lubrication isn't perfect and a little extra protection may save the day - for a street engine, I just don't see it. But, as noted, in the end you need to determine what makes you comfortable and what the risk/reward trade-offs are. I'm definitely not trying to "convince" anyone.
Wonder how much oil temp plays a role in the observation. These motors do run the oil pretty hot. Just thinking out loud I guess.
