Engine makes a whistling noise
Old Jan 1, 2002 | 02:16 PM
Just4Grins's Avatar
Just4Grins
Default Engine makes a whistling noise
The engine on my 2001 coupe makes a whistling noise at about 2800 rpm when under load. I thought it was a squeak in the accelerator linkage at first, but it can be made constant by holding the RPM steady. Hard to duplicate standing still, and I don't have access to a dyno. I have seen threads about the intake systems on modified vehicles, but mine's stock. Any ideas? I can take it to the dealership, but I ran a garage for years and would rather fix it myself if it's feasible.
Old Jan 1, 2002 | 02:29 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default Re: Engine makes a whistling noise (Just4Grins)
My engine started whistling just like yours once I installed the LS6 intake. :( That was not what I had expected from a HP Mod. :nonod: I bet it is your intake on your car. :yesnod:
Whats going to happen when I install the Coil Overs?? Should I expect to hear "Bud"-"Wies"-"er" from the F-ing Budweiser Frogs? :conehead
vetterdstr :cheers:
Old Jan 1, 2002 | 03:22 PM
Blackvette's Avatar
Blackvette
It could be your belt tensioner. I had the same problem and the mechanic told me it is a popular problem.
Old Jan 1, 2002 | 06:47 PM
Just4Grins's Avatar
Just4Grins
Default Re: Engine makes a whistling noise (Blackvette)
Found the part making the whistle. It looks like a vacuum fitting. I have GOT to get a set of shop manuals. Any input on what this is?
Old Jan 1, 2002 | 08:20 PM
Sales@MVPAutoParts.com's Avatar
0Sales@MVPAutoParts.com
Former Vendor
Are you sure you don't a hidden supercharger under the hood. :lol: :lol: :lol:
-Tuan
Old Jan 1, 2002 | 10:27 PM
Pepper's Avatar
Pepper
I have a 2001 manual but need a bit of pointing to know where you located it.
Old Jan 1, 2002 | 10:40 PM
jmX's Avatar
jmX
Thats the EVAP canister purge tube.
Old Jan 2, 2002 | 12:12 AM
Just4Grins's Avatar
Just4Grins
Default Re: Engine makes a whistling noise (jmX)
Thanks for the help. For reference, the fitting is on the driver's side towards the front of the engine.
Old Jan 2, 2002 | 12:32 AM
99 Corvette's Avatar
99 Corvette
Just behind the throttle body :smash:
Jerry
Old Jan 2, 2002 | 06:17 PM
ersatz928's Avatar
ersatz928
The whistle is a known issue with the newly designed (for 2001) intake manifold. It is due to an unused (used for EGR in the F-body version) cavity molded into the intake manifold, where it bolts to the throttle body. At part throttle, a resonance (whistle) is created. Some people have fixed this "problem" by filling this cavity with epoxy.
Old Jan 2, 2002 | 06:41 PM
SoCal C5's Avatar
SoCal C5
Default Re: Engine makes a whistling noise (ersatz928)
:yesnod:
I believe that for 2002 GM addressed the problem. I would check with your dealer or Fitchner Chevrolet to find out for sure. If they have, you should be able to get your manifold switched to the 2002 version under warrantee.
[Modified by SoCal C5, 2:42 PM 1/2/2002]
Old Jan 3, 2002 | 01:11 AM
Just4Grins's Avatar
Just4Grins
Default Re: Engine makes a whistling noise (SoCal C5)
Thanks for the help. I'll contact our local dealer and see what can be done - need to balance the whistling against what can happen once the dealer tears into it....
Old Jan 3, 2002 | 01:25 PM
Rob 2K1's Avatar
Rob 2K1
I had the same whistling noise. I have a 2002 intake at the dealer waiting for installation.
-Rob
Old Jan 3, 2002 | 08:05 PM
HGlide82's Avatar
HGlide82
Default Re: Engine makes a whistling noise (Tuan Le)
-Tuan
Thats what I was going to suggest :)
Old Jan 4, 2002 | 11:58 AM
Just4Grins's Avatar
Just4Grins
Default Re: Engine makes a whistling noise (Rob 2K1)
I took the coupe to the dealer (O'Reilly Chevrolet in Tucson). The service manager heard the noise and said "yeah, the throttle plate is whstling a little bit. There are no ETB's out on this, so I can't do anything about it." The service manager, who has been a pretty good guy in the past, said that he would check with the regional service rep, but I think I'll end up taking this somewhere else. Before I do, is there any documentation from GM on this problem that I can refer to?
To Engine makes a whistling noise
