bbk shorties questions
I live in a state that has emissions requirements (AZ) as well, but my county doesn't currently require it. Poor air quality doesn't stop at the county line, so it's only a matter of time and I'd rather plan now for that eventuality.
Spend my money wisely now, or waste more money later.
You obviously live in a very strict emissions state. It's not going to relax those restrictions any time soon.
Installation of shorty headers is much easier than long tubes, even for a DIY'er.
In most cases, they're less expensive than long tube headers (with related costs incurred).
They don't require an additional expense of a professional tune to recognize the benefits.
They are 50 state emissions legal (B&B, BBK).
They weigh much less than the oem cast iron manifolds.
They look much better...stainless and/or ceramic coated obviously have cosmetic advantages over ugly cast iron.
They will bolt up directly to the rest of your oem exhaust system.
They don't require any other expensive changes to your oem exhaust system.
They offer some change (ie, louder) in exhaust note, if that's your goal.
They obviously won't provide you with the advertised/dyno'ed horse power/torque of long tubes, but they should yield approx. 10 hp improvements. That coupled with the reduced weight is very appealing to me for my type of driving preference.
There are plenty of members here who have installed shorty headers. They all have various reasons for doing so. They've seen and attested to improvements. They may not post often because every time this gets asked, someone has to offer their opinions on why long tube headers are better. No question, but some of us have good reasons to chose shorty headers.
http://forums.corvetteforum.com/show...24&postcount=1
My Dyno Sheet says B&B Shorties, but they are BBK :o
stay CARB compliant
get better looks (jet hot coated)
save some weight (to slightly offset the weight of my KB supercharger)
No I didn't gain maximum HP per dollar spent, but that wasn't my goal.
I installed the B&B's by myself, in the garage, on ramps. It was as easy as swapping exhaust manifolds (because basically that's what it is).
If I was going just for looks, I think I'd jet-hot coat some stock manifolds and remove the heat shields. The stock Z06 manifolds look a lot like headers already......
But yes if maximum HP per dollar is your goal, and you don't care about CARB compliance, go long tubes...
Good Luck...
BTW... yes, I do like them. They look great and mostly, don't make any noise. I like the whine of the Procharger... not "tink" sound of headers.
I hate it when people just out of had take a singular approach... better..even a bit better is better. It all depends on your pain threshold
To maximize your bucks get a used set and then get your car tuned...
So.. are they great? no... just the best we can legally do. They are better than stock (heavy, hot) manifolds.
I showed up with the same tune that I had from my prior dyno session in April at the same shop....The weather on the day of my after-shorties dyno was 40%+ Humidity, so my WOT tune was running richer that the April Dyno (17% RH). The tuner (Charlie) brought my fuel back into line with the prior tune.. Stick to your own experience in which you really know about
- I know the basics of what a long tube header does
- I know that I have yet to see a shorty header on a back to back dyno with as many variables as possible the same make a worthwhile gain.
I don't need to know the specifics of any particular car to weigh the body of evidence and come to a conclusion. There's no way I would spend the money these vendors want on shorty headers for the paltry gains most people see (5-10rwhp). On the plus side they do save some weight and they certainly look better.
Totally, with everything you wrote! I'm very happy with B&B shorties, and with their HP gain. Whatever it is, it is noticeable!!
