New CLB didn't work...Now what do I do?
Old Aug 30, 2008 | 10:37 PM
  #41
mnfmkf's Avatar
mnfmkf
THANKS A MILLION I WILL have someone DO THE FUEL CUTOFF THING AND INSTALL THE CLB
MIKE PORTLAND OREGON
PS I WILL UPDATE YOPU LATER
PLEASE CLARIFY:
RECALL 1 + REMOVAL OF LOCKING PLATE ??
RECALL 2 = K HARNESS INSTILLATION ??
And I guess we can check with GM if we supply the VIN # as to what was done ( if the dealer actually did what they claimed) to our vehicles ????
Visually and clinically we should be able to diagnose these cars.
RIGHT OR WROPNG ???
THANKS again
There needs to be a answer as many are plagued with a problem that the right information should be able to answer.
Thanks again and again
Mike
Old Aug 31, 2008 | 12:18 AM
  #42
JC in XTC5's Avatar
JC in XTC5
PLEASE CLARIFY:
RIGHT OR WROPNG ???
THANKS again
Mike
There are answers in the sticky of this topic at the top of this section.
Old Aug 31, 2008 | 01:57 AM
  #43
mnfmkf's Avatar
mnfmkf
Thanks for the update.
Ill be looking for a shop that can tune out the fuel shut off and go from there to seek a final solution or solutions for my vette.
It should be a reliable car again soon.
Mike
Portland Oregon
Old Aug 31, 2008 | 03:25 PM
  #44
av8or's Avatar
av8or
Originally Posted by rare-72
I cleaned out all the udders. The only thing I have not cleaned is the A/C drain tube. How do you get to it? Also, is there a way to "wrap" the BCM in plastic to protect it from future water damage?
http://forums.corvetteforum.com/show....php?t=1246715
This will help with the HVAC drain.... not sure about protecting the BCM from moisture.
Old Aug 31, 2008 | 11:53 PM
  #45
rare-72's Avatar
rare-72
No wonder I could not find the A/C drain tube. What is the best way to remove and clean it in such a cramped work area?
Old Sep 1, 2008 | 12:16 AM
  #46
rare-72's Avatar
rare-72
Originally Posted by 8VETTE7
I've posted this several times on this board but I'll do it one more time.
There are at least five ( count them for your self) variations of the "fix" that GM has attempted to correct the column locking problems in the C5.
Starting in early 99 the had a Customer Satisfaction Program where they made changes and replaced parts in the cars of customers who complained about issues with the column locking functions. This was the forerunner of the NHTSA forced "recall". It was referred to as CSP 001044. It was GM's attempt to keep NHTSA out of the problem.
In Feb. 04 the NHTSA forced recall began. It was termed 04006 by GM. It was such a poor attempt at fixing the problem that by Aug. 04 they came out with an "improved" version termed 04006A.
This was a total flop and in Nov of 04 they came out with another iteration termed 04006B. This did better and lasted until Jan 06 when they came out with the next and to the best of my knowledge last iteration and it is termed 04006C.
The 04006C iteration is the one where GM authorized the removal of the lock ring on cars built for sale in the US (although some dealers were apparently removing the lock ring on their own earlier than Jan 04.)
Here is a link to the actual GM paperwork sent to dealers for 04006C.
http://corvetteforum.net/c5/kenficht...olumn_lock.pdf
I would love to get my hands on the actual text of the earlier recall variations but at GM's directive each subsequent iteration instructed that the prior version documentation be destroyed. ( you wouldn't want a tech to be installing an outdated fix would you!!!)
The fuel shutoff came with the first actual "recall" (04006). This was GM's CYA in the event someone had the column lock up but still tried to drive the car and got themselves into an accident. Sure fire way to prevent a lawsuit. It was implemented by a reflash of the PCM that set the fuel shutoff speed at 2MPH in the event that the BCM "thought" the column was locked. Side note, EFI Live and HP Tuner software can set the fuel shutoff speed to a larger number. The GM Tech II and all other similar tools cannot.
What makes these column lock problems so difficult to resolve is that many cars had more than one of the variations applied to it and the fact that some dealerships were not implementing the fix as directed by the GM documentation. Add to that the crappy relays and wire harness that GM was providing and the complexity of the whole column lock implementation as GM designed it. It is a well known fact that the GM solution IS going to fail sooner or later.
The CLB is the best solution as yet available to keep owners from getting stranded. Two different things can strand you. 1) The column can actually lock up if the lock ring has not been removed. 2) The BCM may get into a confused state and think the column is locked when it is not and then signal the PCM to implement the 2mph fuel shutoff.
Installing a CLB however, can be tricky because you need to disconnect the GM solution(s). This is because the CLB wants to be the sole communicator with the BCM to "fool" it with respect to the status of the column being locked or not. If there are remanents of the GM solutions in place, the CLB cannot reliably control the signals being sent to the BCM. The tricky part is determining what GM did to a specific car so that it can be disconnected or bypassed.
My car is one that had numerous factory "fixes". The Customer Satisfaction Program, K harness (not sure which version), lock ring removal, and fuel shutoff reflash.
So my column will never lock, but the car thinks it locked, so it shuts off the fuel. The dealer will be replacing the BCM since neither the new CLB. K harness, or even original connection, minus K harness, will convince the BCM that the column is not locked. Fuse puling to reset the BCM did not work either. I cannot find anyone in the area that can "raise the speed limit of the fuel shutoff". So, I gave up an let the dealer have it. I'll know on Tuesday when the tech installs the new BCM.
Old Sep 1, 2008 | 01:02 AM
  #47
427435's Avatar
427435
Is this true for M6 cars also?? There are no outstanding recalls on my car but the steering column locks when the key is turned off.
Old Sep 1, 2008 | 11:22 AM
  #48
JC in XTC5's Avatar
JC in XTC5
Simple answer - MN6 cars will still lock with the GM recalls. They will not remove the locking plate because that would result in no immobilization capability. A4s still have the brake/shift interlock for immobilization.
Having said that you're living on borrowed time. All of GMs recalls have not been successful. For A4s, the Harness K relay is faulty causing the BCM to shut fuel. For MN6, depending on which recall they did they may have modified the relay near the BCM but the locking motor is still capable of locking up and stranding you.
You basically need a CLB but need to confirm that they didn't modify the relay near the BCM otherwise the CLB will not work until you restore that relay modification back to original. It's all in the sticky section above.
Old Sep 1, 2008 | 11:24 AM
  #49
JC in XTC5's Avatar
JC in XTC5
The issue becomes which iteration of the recall was done to your car.
By the book, GM only had to do 04006. They met the requirements of NHTSA with it. In reality they came out with the other variations because customers were complaining that the problem either was not corrected by 04006 or had come back (in the form of the fuel shutoff more often than not) because one of the components of the fix had failed. In some instances GM told customers they had to pay for a newer variartion if GM had already applied an earlier iteration. In many instances they did pick up the tab for a later variation being applied even though an earlier one had been applied at GM's expense. It depended on whether the dealer wanted to stand up to GM on behalf of the customer.
If iteration 04006B was done to your car then the GM Service History would show that you had no outstanding recalls. However, since the removal of the lock ring was directed only in 04006C, your column would likely still lock.
Hope this makes sense to you.
The variation of the recall depends on whether you have an A4 or MN6.
Old Sep 1, 2008 | 11:43 PM
  #50
JC in XTC5's Avatar
JC in XTC5
That variation depending on A4 or M6 was TRUE for all recalls EXCEPT variation 04006C. If your car received 04006C the recall prodedure is exactly the same for US delivered cars, M6 or A4.
Here's the text for 04006C that all GM dealers received.
Read for your self . The procedure to be followed for all M6 and A4 cars delivered in the US was 1A (page 3 middle of the page) and it removed the lock ring. Recalls variations prior to 04006C ( ie 04006B, 04006A, 04006 and CSP 01044) were not authorized by GM to remove the lock ring.
You're right. I keep forgetting that GM's last feeble attempt to address this issue was to remove the locking plate on MN6s and install the Harness K, which was originally only for A4s. With my CLB since day one I've been able to avoid all this.
Old Sep 2, 2008 | 07:16 PM
  #51
rare-72's Avatar
rare-72
Default It's Alive....Alive
Well for all of you that have been . Here is the outcome of my Column Lock Fiasco. According to the dealer, both the BCM and BCM relay were on the fritz. First they replaced the BCM and it would not communicate with the relay. Then they installed a new relay with the old BCM. Same issue. So they installed both new parts and no more fuel shutoff!
I was sure it was the K harness. Well it turns out the K harness is working fine. They did install the CLB but it gave the "Remove Key Wait 10 Seconds" warning. So they reinstalled the K harness, and no more warning messages! No wonder the Column Lock drives C5 owners nuts! I'm so glad I bought that service contract.
Did I get a defective CLB?
Old Sep 2, 2008 | 08:54 PM
  #52
rare-72's Avatar
rare-72
Congrats on being able to drive the car faster than 2MPH.
Not sure of the procedure that they used to install the CLB but I would use the one in this link to try and install it again:
http://www.ls1howto.com/index.php?article=24
It has a step to follow if you get the error message. Use the step to try and clear it. If the error message continues then I would have to suspect the CLB is bad. (Or perhaps was damaged by the other bad components you had???)
If you decide to try the CLB again please post the results.
By the way did he mention where the "BCM RELAY" was located? Was it in the passenger footwell under the BCM?
I'll try the CLB again and see if I can clear the code. The tech mentioned the CLB relay was in the footwell, but I think he said it was mounted on the toeboard "above" the BCM. I'll give him a call and get a better description of where exactly it is mounted.
I am still wondering if it could have been affected by the water intrusion during the heavy rainstorm I was caught in. The water (basically damp carpet) was located near the center console and the area around BCM appeared completely dry. Where can water get in that would affect the BCM, and BCM relay?
Old Sep 3, 2008 | 09:09 AM
  #53
bluvette79's Avatar
bluvette79
good job!
now back to driving!
Old Sep 3, 2008 | 11:41 AM
  #54
JC in XTC5's Avatar
JC in XTC5
The Column Lock Relay is what you're referring to. It's the left most of the 3 relays right above the BCM and it sends the lock/unlock voltage upstream to the Column Lock Actuator (or Harness K/CLB if installed). It sounds like the CL Relay fried and may have damaged the BCM which is why both needed to be replaced.
Also remember that an earlier recall modified the wiring around the CL relay near the BCM. That modification was not compatible with the CLB which could be why your CLB was throwing the code.
Old Sep 3, 2008 | 01:19 PM
  #55
rare-72's Avatar
rare-72
Alrighty then. I have lost track of how many factory fixes there were for this problem. How would I know if my wiring has been modified? I have all the service records but there is no direct mention of this.
I guess I purchase a CLB that may be usless for me.
I'm just happy it's driving again
Old Sep 3, 2008 | 09:22 PM
  #56
77BlueL82's Avatar
77BlueL82
Some cars need the relay. Some cars don't need the relay. I had the same problem. I thought it was fixed, then bam, 2MPH. The dealer called Detroit, took out the relay and the car has been fine since. I hope I didn't just jinx myself.
Old Sep 4, 2008 | 01:04 PM
  #57
ROCKnROLL's Avatar
ROCKnROLL
Veteran
PM sent
To New CLB didn't work...Now what do I do?
Old Sep 4, 2008 | 04:13 PM
  #58
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
not for long with that dreaded k-harness still in there.
Heres what you need to do..
1. PCM needs to be flashed back to OEM (pre- GM recalls state) Call Corvettes of Westchester to do this
2. Ditch the k-harness
3. Install CLB from ThunderRacing. I never heard of the brand you mentioned. Does it say JMX on it? then keep it if it does because they are all the same.
CL issue is resolved for life.
Old Sep 5, 2008 | 01:38 AM
  #59
rare-72's Avatar
rare-72
Thanks for the info on the reflash and CLB.
Old Nov 14, 2008 | 12:20 AM
  #60
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Default Hey dude..Call me. I'll help ya.
Hey man.... I got the best fix in the business.... NEVER GET STUCK AGAIN!
Call me any time.
Chuck CoW
