Battery Suggestions
Old Aug 18, 2008 | 04:13 PM
GlenE's Avatar
GlenE
Default Battery Suggestions
I have read a lot of threads about batteries. A lot of people like the Red Top Optima. I have also read a lot of stuff about the Optimas not being what they originally were, quality wise. I really don't want to put in a wet cell so what options do I have? I've read about Odyssey but they are more expensive than almost everything out there, on the other hand, my 03 AE is worth it if the quality and reliability is there. Your thoughts.....
Old Aug 18, 2008 | 04:27 PM
hotwheels57's Avatar
hotwheels57
If you've read through the hundreds of past discussions on this very topic, you've probably realized that there is no consensus of opinion. I strongly suspect there won't be any consensus in this thread, either.
Everyone thinks their choice is the best. Most will agree that they don't want to have battery acid dripping onto the computer. That's about the only thing that most agree on.
I've been using OPTIMA batteries prior to the time they were even available to the general public. I've never had one fail. I have one in each of our vehicles except my '07 Silverado. When the oem battery on that needs replacing, it'll get an OPTIMA red top as well.
...it's your car to do with as you please.
Old Aug 18, 2008 | 05:12 PM
GlenE's Avatar
GlenE
Which red top do you use? The application sheet shows a 75/25. Will the higher CCA 34/78 fit?
Old Aug 18, 2008 | 05:23 PM
hotwheels57
I got mine from COSTCO in June '06. It's a group 75/35 which is top mount and side mount. It only required the slight angling of the battery cables (top mount) in my '04. The cables were long enough and it fits right into the oem tray and uses the oem hold down. There are adapters available through OPTIMA if you opt to use another size.
If you go to the OPTIMA website, you can determine your battery by application. OPTIMA recommends a group 25 for many of the C5/Z06 Corvettes.
http://www.optimabatteries.com/
As far as the 34/78 fitting, I'm not certain. You'd have to compare dimensions. I think in some past discussions, some members have said they used that group size. Maybe it requires the adapter?
Old Aug 18, 2008 | 05:47 PM
GlenE's Avatar
GlenE
Thanks for the info. Greatly appreciated.
Old Aug 18, 2008 | 06:03 PM
hotwheels57
You might also consider some type of float maintenance charger for whatever battery you decide to buy. They'll keep the battery fully charged during periods of non use. The C5/Z06 has lots of electronics (memory) to maintain.
Such devices slowly charge the battery to full capacity, then go into "sleep" mode unless the battery needs to be charged again.
I only have experience with BATTERY TENDER PLUS (1.25 amp) which is perfect for the OPTIMA battery. They also make other models for other brands of batteries. They have a warranty up to 10 years. I maintain the OPTIMA in my Z16 with this model for winter storage.
CTEK is the latest rage in high tech chargers. It's from Europe and has some features not available to the BATTERY TENDER PLUS. It costs only $10 more. I'm not certain of the warranty. I'll probably consider one of these should my BATTERY TENDER PLUS ever fail me.
Old Aug 18, 2008 | 06:10 PM
Andrew@MarylandSpeed's Avatar
0Andrew@MarylandSpeed
Former Vendor
I favor the Optima yellow top. It's a deep cycle battery, so if you DO end up draining your battery several times it won't kill the battery. It's great for all of the electronics that these cars have. We just put one in the shop Z06 last week because the factory battery just wouldn't hold charge anymore after being drained 3-4 times from just sitting.
We now have a Battery Tender on it but if the new Optima was to drain it wouldn't hurt the battery.
Old Aug 18, 2008 | 08:33 PM
LoneStarFRC's Avatar
LoneStarFRC
The 34/78 does fit. I've had one in mine for almost 6 years.
Old Aug 19, 2008 | 12:56 AM
GlenE's Avatar
GlenE
I usually use a Battery Tender Plus. I happened to not leave it on a few times and the original battery was down to around 10v. It does take a charge. I just want to be ready in case of failure. I have to start looking for deals on an Optima. Might go with the higher CCA of the 34/78, it is just slightly longer but same width and height of the 75/25. Thanks for all the input.
Old Aug 19, 2008 | 03:56 AM
bassman12350's Avatar
bassman12350
The Yellow Top is possibly a better choice for the later 'Vettes, due to their large electrical demands and tendency to draw significant current when the engine is off and the car just sits. Both the Yellow and Red Tops have the same gel-cell technology and are suitable for use in rough service / high vibration applications. The difference lies in the higher standard (32 deg) cranking amps and CCA factors, where the Red Top has higher values. The Yellow Top has a better reserve capacity and is designed for occasional deep cycle situations, for which the Red Top is not. Anyway.......MHO.
Old Aug 19, 2008 | 09:58 AM
Dave68's Avatar
Dave68
Really, the days of the leaky battery are long gone. There is no need to worry about something that will in all likelyhood, never happen. That being said, it is well known that most AGMs do not like to sit for any length of time. This is primarily why AC Delco discontinued its AGM batteries. If you drive your car often or keep a battery tender on it when you don't, you should be happy, but the fact remains that a good non-AGM tolerates periods of inactivity far better than does an AGM. The deep cycle AGMs, such as the Yellow top are better in this regard, but deep cycle batteries on average do last as long as standard batteries if both are charged regularly. You can get 7 years out of a standard battery but few Yellow tops last that long.
I chose the 7 year AC Delco Professional; it comes with a 50-month FREE replacement warranty - better than any other.
Old Aug 19, 2008 | 12:05 PM
Last C5's Avatar
Last C5
The Optima was the greatest thing since slice bread for a long time, then they went through a period where their quality control slipped badly and they didn't last six months. That period damaged their reputation and they have suffered from that damage ever since. They seemed to have cured the quality control problem now as their current crop of batteries seem to be performing well.
All that said, I run the Odyssey and I'm very happy with them.
Old Aug 19, 2008 | 01:45 PM
JC in XTC5's Avatar
JC in XTC5
I replaced my Delco two years ago with an Exide Orbital AGM battery. The reviews on it were very good, the design seems to be solid,and I've had no problems thus far. I also hook it up to an Deltran BT Plus if it's going to sit more than 10 days without moving.
Check out the Exide Orbital. The price was $129 at NTB.
http://www.exide.com/products/automo...t_orbital.html
Old Aug 19, 2008 | 03:10 PM
warpster's Avatar
warpster
My last RedTop died a couple months back (had it for 3 1/2 years) due to me not keeping it fully charged...so it wouldn't charge up fully anymore. I took it back and used the warranty and only paid $60 for a new RedTop. The warranty came in handy, the YellowTop's only have like a year warranty! The Sears Diehard Platinum has a 4 year replacement and an additional 100 month pro rated warranty! It's also a glass mat battery but it's a little on the expensive side at $189
Old Aug 19, 2008 | 03:12 PM
warpster's Avatar
warpster
What is NTB????
Old Aug 19, 2008 | 04:37 PM
byronhunter's Avatar
byronhunter
Default Ntb
http://www.ntb.com/
Old Aug 19, 2008 | 05:49 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
I also went with the Excide Orbital and am very happy with it (and I'm also running a 2 600 watt amps in my stereo set up)
I've let my car sit 2-3 weeks before when I have not had time to drive it, and I never even put the Batter Tender on it and it starts up fine everytime. In the winter, when the car sits for a few months, then I put the tender on it.
FWIW my original Delco AGM lasted 6 years and was still going strong when I pulled it out.
I am an Optima hater I'll admit..after reading countless threads here on them failing after sitting just one week, it was a no-brainer for me. ..also having 3 friends with vettes all having poor experience with them too. They are JUNK.
To Battery Suggestions
Old Aug 20, 2008 | 04:06 PM
GlenE's Avatar
GlenE
Best place to get an Orbital? Which model, 75 or 78? My local Batteries Plus has both Optima and Orbital and they have had a high number or Optima returns the past six months. Have had no returns on Orbitals. Their cost on an Orbital 78 is $160.
Old Aug 20, 2008 | 04:55 PM
JC in XTC5's Avatar
JC in XTC5
The fitment guide on the 2000 C5 calls for a 78 but it seems to vary for other years. Basically the difference in size between the 78 and the 75 is the 78 is 1.125" wider. Check the specs for the right size. See if there's an NTB in your area as I found they had a good price.
Old Aug 20, 2008 | 05:26 PM
Nyvetteguy007's Avatar
Nyvetteguy007
Have the Sears Platinum for over a year now....LOVE it!!
