electrical problems
Old Aug 21, 2008 | 04:17 PM
03z06BLK's Avatar
03z06BLK
Default electrical problems
First off the window,mirrors and the door lock will not work. It also says reduce power service abs and traction control. Here are the codes I pulled. 10 pcm, 28tcs, 99hvac, ad-ldcm, a1rdcm, a6-scm, bokfa. This is a 2001. Thanks guys.
Old Aug 21, 2008 | 05:37 PM
lucky131969's Avatar
lucky131969
That doesn't help knowing how many codes there are, you need to list them.
http://forums.corvetteforum.com/show...ight=dtc+codes
Old Aug 21, 2008 | 11:38 PM
bestvettever's Avatar
bestvettever
Default Electrical Problems
Hi, what you are describing is very often caused by :
1, a bad battery--get it load tested.
2, Loose or corroded cables connected to the battery, the cable on the starter lug, or the cable connected to the underhood fuse block.--Need to examine these areas for loose or dirty connections. Read Bill Curlees thread on ground cleaning and electric issues
3, Bad grounds, especially the star grounds on the frame rails. and the neg batt ground.
Start with the above and you will probably not have to go any further. Post if you need more info
Good Luck
To electrical problems
