Muffler installation.
Old Aug 22, 2008 | 04:08 PM
540 vette's Avatar
540 vette
Default Muffler installation.
I am replacing the l/s muffler on my 99 with the same style stock one. I cut the old one out. Now how do I get the replacement back in there.
Old Aug 22, 2008 | 04:36 PM
AMRAAM's Avatar
AMRAAM
You will have to have the rear of the car pretty high inorder to snake it over the axle. if you have access to a lift, I recommend you use that. I think I read that you need like 39" of clearance.
Old Aug 22, 2008 | 06:42 PM
itzza427's Avatar
itzza427
It helps a LOT if you drop the inner (cross member mounted) sway bar mounts. I didn't drop mine right away and wrestled with it for 20 min. trying to get the pipe up and over Dropped the bar mounts and the pipes almost fell out.This is on a M6 tranny,,don't know about the A4!!
Old Aug 22, 2008 | 10:11 PM
AMRAAM's Avatar
AMRAAM
100% I forgot about that.
Old Aug 22, 2008 | 10:13 PM
byronhunter's Avatar
byronhunter
Same for A4 on left side!
Old Aug 22, 2008 | 11:38 PM
540 vette's Avatar
540 vette
I lifted the rear of the car up about 36 inches and removed the sway bar mounts and moved it out of the way. It just about fell in.
Thanks guys
steve
Old Aug 22, 2008 | 11:54 PM
itzza427's Avatar
itzza427
Thanks guys
steve
Almost fun wasn't it!!
Old Aug 23, 2008 | 09:41 AM
AMRAAM's Avatar
AMRAAM
Thanks guys
steve
Glad it worked out for you.
To Muffler installation.
