Horn
Old Aug 24, 2008 | 11:32 AM
ACOIII's Avatar
ACOIII
Cruising
Default Horn
My horn stopped and working and I did notice that my fuse was burned out....So I replaced the fuse and it still doesnt work...
Suggestions?
Old Aug 24, 2008 | 12:44 PM
JC in XTC5's Avatar
JC in XTC5
It's likely the membrane in the steering wheel with the horn contacts is broken. This is very common and the only way to officially repair is to replace the airbag section (very $$$). Someone did post a way to remove the center wheel airbag section and repair the horn contact/membrane.
Old Aug 24, 2008 | 12:53 PM
FourG63 97GST's Avatar
FourG63 97GST
does it work with the alarm/when locking locking with the keyfob?
Old Oct 23, 2008 | 08:12 PM
SeaDogJoe's Avatar
SeaDogJoe
I've tried to find the thread mentioned above by JC--no luck.
Anyone help please with this??
My horn doesn't work with the horn pad on the steering wheel. The fuse and relay are ok. I DONOT want to spend big $$$$$ to replace airbag assembly. Has anyone mounted a horn button and run a seperate wire to the horn??
Thanks in advance.
Old Oct 23, 2008 | 10:18 PM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
Thanks in advance.
Are you able to read a Word document? If so, PM me your e-mail and I'll send it to you. I don't think I can post it here.
To Horn
