Brake rim weight reduction
Old Aug 28, 2008 | 04:46 AM
lubranjo's Avatar
lubranjo
Default Brake rotor weight reduction on Z06
Just a queston s I am looking to reduce rotating weight on my Z06 and yes I have become obsessed... LOL Has anyone replaced stock brake rotors with say Eradispeed or any others the reduce rotating mass by almost 4 lbs per rotor ??? I know the visual look is better. Just curious to how much HP equiv. reducing say 15 lbs of rotating weight is worth...Thanks... (Stock Rims I like the look)
Old Aug 28, 2008 | 06:42 AM
jdmvette's Avatar
jdmvette
Night Owl for life
get a set of carbon ceramic rotors and you'll be good to go.
Old Aug 28, 2008 | 07:12 AM
AU N EGL's Avatar
AU N EGL
each lb of rotating wt is ~ 6.5 lbs of sprong wt
so 15 x 6.5 ~ 97.5 lbs removed from your car.
Ok make that 100 lbs, and ~ 10 hp increase
Stock rotors are 11 lbs fronts and 7 lbs rears
when looking at 2 piece rotors dont forget to add in the hat and hardware
Old Aug 28, 2008 | 05:13 PM
lubranjo's Avatar
lubranjo
Ok, I am slow but now confused as Eradispeed says there rotors are 38 lbs... weight savings ???? But they claim "weight reduction on the write up...
Old Aug 29, 2008 | 10:48 AM
nitrojunky's Avatar
nitrojunky
Re the above post about weight savings...
How much 'weight' they save strongly depends on where the reduced mass is located. From a rotational perspective, reducing mass at a large radius is much more important than reducing mass at a small radius, i.e. losing 4 lbs off the hub or hat is much less advantageous than losing it off the edge of the rotor. Losing 1 lb off the tire is probably worth more than losing 4 lb off the hub (goes by r^2). The prob with brakes is... if you lose the weight off the rotor section, it'll change a lot of thermodymic effects so I'm not so sure it'd be worthwhile. They'll cool quicker, but they'd be more likely to warp, and they'll also heat more quickly...
From a non-rotational standpoint (suspension rebound), it won't matter where you lose it on the wheel/brake.
Old Aug 29, 2008 | 06:47 PM
lubranjo's Avatar
lubranjo
Thanks to you all !
To Brake rim weight reduction
