Codes Stopped
Old Aug 29, 2008 | 06:04 PM
KayCee's Avatar
KayCee
Default Codes Stopped
I was having continuos codes for various Active Handling just about everyday on my 2002 C5. I would keep the Active Handling turned off. I started my 50,000 mile service by changing both drive and AC belts last weekend and the codes stopped.
I can't see the connection. Has anyone else experienced this phenominum?
Old Aug 29, 2008 | 07:04 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
You might want to post the codes you were seeing.
Old Aug 29, 2008 | 08:02 PM
c5streak's Avatar
c5streak
What codes were you getting?
It's possible you may have bumped the connector on the EBCM while working in that area, and "fixed" a bad connection.
Old Aug 29, 2008 | 08:17 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Old Aug 30, 2008 | 10:47 PM
KayCee's Avatar
KayCee
It was tripping codes C1282 and C1287. I have driven for a week and no codes. I had already pulled the two ground plugs behind the light assemblies and was working my way through all of them. This is a California car so the ground connectors were just like on those two. Getting the altenator belt on was a wrestling match to get the belt lined up on all the pulleys at one time. I figured out a short cut of removing the idler pulley and washers and using the pulley sprocket shaft as a temporary belt holder, then pull the tension off and push down on the belt with the pulley to seat the belt. It's a ten minute job now.
Anyway, that was a long story to say that, you are probably right in that I bumped something and made a better connection. That alternator belt was a struggle for a couple hours and almost a whole six pack.
Thanks for the response.
KC
To Codes Stopped
