im replacing the cassette player with a stock bose in dash cd/player and also am installing a changer in the back. here is my question-- are all of the stock cd players equipt with the right connector to the harness to the changer in the rear? im told there is a 10 pin connector but dont know how true that is. thanks--
There are early and Late model CD changers. Ive been told,,that they cant be exchanged. Not sure if thats true or not. I have a changer infront of me. Pioneer PN = 25685332. There are TWO connectors on the bottom of the changer. One connector has 4 pins and the other one has 6.
You will need the cable that connects the front to the CD Change.
It connects in the passenges foot well down near the fuse box.
BC
BC
thanks for the quick reply,what im asking is do all of the cd player/radios come equipt (do they all have ports in the back) to connect to the changer?
NO! I believe that the 97 & early 98 C5s have a hard wire to the rear unit. The 99 and later units have connection plugs in the pass foot well that you need to connect to. I had to connect to them to get a CD Changer in my 02 Z (They didnt come with CD Changers) If you have a later unit,,,your all set. I have picts of the connections if you need them. send me your e-mail adderss and Ill send them to you.
