cooling system surge tank cap
Old Aug 30, 2008 | 01:56 AM
PDQC5's Avatar
PDQC5
Default cooling system surge tank cap
I have a 98 A4 coupe and recently have had an issue with coolant pushing out past the cap when the engine is shut off and the coolant temp is 220 degress or higher. since I was not having any other issues I decided to start by replacing the cap. I picked one up today and when I got home realized that the new cap has a 18 psi rating but the old cap has a 15 psi rating.
any one out there know why they changed to the 18 psi cap? the 15 has worked fine for the 5 years I have owned the car.
Old Aug 30, 2008 | 07:56 PM
Oldvetter's Avatar
Oldvetter
Been reported before, they just changed. Remember, higher pressures equals better cooling. Call it progress.
Old Aug 30, 2008 | 08:46 PM
warren s's Avatar
warren s
The RC87 cap (18 psi) is used on the later years C5s. Its one less part the dealer has to stock (the 15 lb cap) as the newer cap is backwards compatible with the 97 to 99s.
Cant say exactly why GM changed the spec, but the extra 2 pounds of pressure will allow a higher water temp before boil-over.
The newer cap also cant be over tightened by a garage monkey - it will ratchet like the gas cap once it tight enough on the plastic overflow tank.
Old Aug 30, 2008 | 09:39 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
EXCELLENT DATA!!!
BC
Old Aug 31, 2008 | 11:14 AM
PDQC5's Avatar
PDQC5
Thanks for the replys, and by the way changing the cap fixed the problem.
To cooling system surge tank cap
