10% ethinol in oklahoma
Old Aug 31, 2008 | 09:38 AM
widewheel's Avatar
widewheel
Default 10% ethinol in oklahoma
Here in Oklahoma as of July all of the gas station pumps are labeled "may contain up to 10% ethinol". Is this something that is going on nationwide yet? I have been told by some friends that work in refineries that they have been mixing ethinol for some time. There is only one station here in the small town that I live in that advertises "pure" gasoline. It's a Diamond Shamrock but he doesn't sell premium. All I can say is that I noticed that the Vette seems to be getting slightly worse gas mileage. I'm just hoping this stuff isn't damaging the fuel system.
Old Aug 31, 2008 | 10:40 AM
itzza427's Avatar
itzza427
You are good to goIt's pretty much nation wide,,I was actually kind of surprised to hear there was somewhere that didn't have it!! Illinoi an many others hafe had it for years with NO TROUBLE !! No real problems even in my 69 big block(I did have hardened valve seats put in the heads for unleaded gas). As you noted you get a small MPG drop and that's it. Kind of ironic they put 10% in to stretch the gas supply,,but you have to burn more of it because it's in there!!
Old Aug 31, 2008 | 01:07 PM
Purerock105's Avatar
Purerock105
Especially if you're on vacation out of your homestate, you're bound to have to pump it in. Florida pumps too have been integrating 10% ethanol. No issues here.
Old Aug 31, 2008 | 02:44 PM
ZeeOSix's Avatar
ZeeOSix
Dust off your owner's manual ... it talks about what fuels are acceptable. Up to 10% ethanol (ethyl alcohol) is listed as acceptable. The alcohol will help keep your fuel system water free ... but yes, you will see worse fuel mileage.
Now the nasty crap they sell in CA might use wood alcohol instead of grain alcohol and some nasty anti-corrosive additives. Stay away from those fuels if possible.
Old Aug 31, 2008 | 08:10 PM
tiojames's Avatar
tiojames
Alcohol attracts water to the fuel system. Letting alcohol sit in fuel tanks will attract water.
Old Aug 31, 2008 | 09:15 PM
Bill Dearborn's Avatar
Bill Dearborn
Its required by law. They replaced the MTBE additive with Ethanol a couple of years ago. Although MTBE reduced exhaust emissions (not CO2) it caused water pollution. Another win for the environmentalists. They forced MTBE on us and then when it didn't work out they blamed the oil industry.
Bill
Old Aug 31, 2008 | 11:36 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Ethanol is crap. I new magazine study showed that an E85 vehicle on E85 got 15% worse milage than a standard vehicle on pertol-based gasoline.
While it won't hurt your engine, your milage will go down.
Can ANYONE tell me if there's a good reason to have ANY Ethanol in our fuel?
Old Sep 1, 2008 | 12:24 AM
turboed's Avatar
turboed
i was wodering what would happen at 11to 1 compression cause thats where i want to raise mine to and all pumps have that crap down here,anybody tried?
Old Sep 1, 2008 | 12:37 AM
ZeeOSix's Avatar
ZeeOSix
Yes, that's correct and that is what I meant by keeping the fuel system "dry". The alcohol will totally absorbs the water ... it doesn't cause water to appear in the system. Go look at what the ingredient is in a typical "fuel dryer" additive. The earlier statement I gave was accurate.
Old Sep 1, 2008 | 12:38 AM
ZeeOSix's Avatar
ZeeOSix
Supposedly less pollution emissions from ethanol. Go search the 'net for details.
Old Sep 1, 2008 | 03:26 AM
LoneStarFRC's Avatar
LoneStarFRC
Must not get out too much, huh? Texas has had that 10% blend for a good while now. At least in Texas 93 octane is still widely available. Oklahoma is stuck with 91, pretty much throughout the entire state.
Old Sep 4, 2008 | 02:44 AM
DalTexVet99's Avatar
DalTexVet99
I have been buying 93 octane with the ethanol here in texas and just noticed a slight difference in gas mileage but thats it. I agrre that it make no sense to be using it to begin with.
Old Sep 4, 2008 | 03:36 AM
Justin-Sane's Avatar
Justin-Sane
check your PM'S
Old Sep 4, 2008 | 08:02 AM
AU N EGL's Avatar
AU N EGL
almost all fuel is 10% EtOH now.
Old Sep 4, 2008 | 08:37 AM
MIF32223's Avatar
MIF32223
Working for a fuel distributor here in Fla everyone has gone ethanol. The why is that there are tax advantages from the feds, since it is made from a renewable source. There is allot less energy in ethanol than gasoline so you will see around a 10% decrease in mileage. Ethanol does "absorb" water, until it gets saturated with it, then it causes "phase seperation" where the alcohol/water will "drop out" of the gasoline, something you don't want in your tank. The ethanol will clean your cars fuel system and raise havoc with those pesky fuel level senders.
Old Sep 4, 2008 | 09:05 AM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
I agree. I used to be able to get 350+ miles per tank. Now it's down to 310. (same driving route and time of year)
Old Sep 4, 2008 | 09:25 AM
jrose7004's Avatar
jrose7004
It's hard to avoid, you've been pumping it in for years, you just didn't know it until now.
To 10% ethinol in oklahoma
Old Sep 4, 2008 | 10:02 AM
VIPERBLUELX's Avatar
VIPERBLUELX
Bill
Maybe in your state, but in Georgia it's option. I run a gas station and we sell 100% ethanol free fuel and will continue to do so till the feds make us start selling blended fuel. Ethanol is not a solution, farmers can't grow enough corn to supply the ethanol needs so the government is subsidizing the farmers and having them grow corn instead of other needed crops, causing the other crop prices to increase.
The overall environmental harm from processing ethanol is more harmful to the environment than running straight gasoline.
Old Sep 4, 2008 | 10:37 AM
jon c's Avatar
jon c
there are a few places in Okc that you can buy 93 and higher it just costs a small fortune....
Old Sep 4, 2008 | 11:04 AM
Fast Cop's Avatar
Fast Cop
Same thing here in South Carolina. "May contain no more that 10% ethonal" Mo issues cars run fine.
