Torque Question
Old Aug 31, 2008 | 12:14 PM
darbn's Avatar
darbn
Default Torque Question
I have a 1/2" drive torque wrench. I need to get a 33mm nut up to 118 ft-lbs. If I use a 1/2 by 3/4 adapter (the 33mm socket is 3/4) on the torque wrench does this change the precision of the torque? Thanks
Old Aug 31, 2008 | 12:31 PM
Patches's Avatar
Patches
I use adapters on torque wrenches with good effect as long as the components are of good quality and in good condition. I have cross-checked with non-adapter setups and found no significant difference.
Make sure you torque slowly to get the best result.
Old Aug 31, 2008 | 12:42 PM
darbn's Avatar
darbn
Much appreciated.
Old Aug 31, 2008 | 12:56 PM
nitrojunky's Avatar
nitrojunky
As long as you tighten -slowly- it will not make a difference, pretty much regardless of the quality of the adapter.
Trivia: because it doesn't put its torque down slowly (the dynamics of be situation being that the adaptor can twist & untwist, absorbing a significant portion of each pulse), using an adapter with an impact wrench will dramatically affect the torque it puts on a nut.
Old Aug 31, 2008 | 01:00 PM
c5streak's Avatar
c5streak
Adapter + impact wrench = I can't get this damn nut to break loose!!!
Old Sep 1, 2008 | 11:28 AM
99 vett babycar's Avatar
99 vett babycar
Get yourself a 4 foot piece of pipe to user asw a breaker bar and you'll be able to break the engine loose.
Old Sep 1, 2008 | 01:59 PM
lionelhutz's Avatar
lionelhutz
It's fine as long as what you are using leaves the bolt in line with the square drive of the torque wrench. Something like a crow's foot that moves the bolt off to the side will affect the torque.
Peter
Old Sep 1, 2008 | 02:06 PM
ZeeOSix's Avatar
ZeeOSix
Peter
... the torque setting will only change if you change the lever arm length of the configuration. If you search the internet, you can find correction formulas for different setups like crow's feet and offset adaptors, etc.
http://www.trialsnuts.com/TORQUED.pdf
http://www.engineersedge.com/manufac...e_wrench_1.htm
http://www.engineersedge.com/manufac...e_wrench_2.htm
Old Sep 1, 2008 | 02:26 PM
lucky131969's Avatar
lucky131969
No, because the axis of rotation,thus the torque applied about that axis, is the same.
To Torque Question
