2004 corvette convertible
Old Sep 5, 2008 | 03:40 PM
slydercorvette's Avatar
slydercorvette
4th Gear
Default 2004 corvette convertible
all kinds of P Codes P1125 P1231 and TCE codes keep coming on Traction
light keeps coming on also C1287 and C1278.. check engine light also on.
"ENGINE REDUCE POWER" ALSO COMES ON :-(
does anyone know of a Corvette man in Scottsdale Arizona that
is good with 2004 corvettes?
It has z06 wheels on it the rr are larger than the front... Also a K&N filters have
been added by the original owner...
Please help
Mike
m.guider@contractcadservices.com
Old Sep 5, 2008 | 05:45 PM
AU N EGL's Avatar
AU N EGL
Your YAW sensor may be bad
Our 2004 vert had this. We took it too the dealer and they changed the YAW sensor ( under the Passenger set next to the tunnel )
Old Sep 5, 2008 | 06:54 PM
slydercorvette
4th Gear
What is a YAW sensor?
Mike
Old Sep 6, 2008 | 09:43 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
The traction control codes are a result of the engine going into reduced power mode, if you solve that then your problem is fixed.
What exactly are your PCM fault codes?
Old Sep 6, 2008 | 02:41 PM
slydercorvette
4th Gear
I'm getting P 1125 and P1280....Accelerator Pedal Positioning Sensor 2 circuit
P1281....Accelerator Pedal Positioning Sensor 2 circuit out of range
but I have no idea where this sensor is found in my 2004 vette...
Hmmmm
Please help its annoying as hell :-(
Old Sep 6, 2008 | 04:31 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Hmmmm
I don't have my manuals in front of me to give detailed troubleshooting help, but this is definitely your problem. The accelerator pedal position sensor is the actual gas pedal that you hit with your foot, when you depress that pedal it sends a signal to the TAC module which then relays it to the throttle actuator on the throttle body.
The majority of the time the TAC module is what actually faults but in your case it sounds like it the accelerator pedal.
To 2004 corvette convertible
