Tire pressure problems
Old Sep 8, 2008 | 02:16 PM
LATNC3's Avatar
LATNC3
Default Tire pressure problems
on my 98 vette, the tire pressure at the dash reads 25psi but when manually checked i'm at 28 to 30. any reason why i would have such a large difference?
Rod
PS. the front left is where i have this problem!!!
Old Sep 8, 2008 | 04:09 PM
R Devil's Avatar
R Devil
Original batteries? If so, it's probably near the end of it's life.
Old Sep 8, 2008 | 04:59 PM
Corvette Don's Avatar
Corvette Don
I have a rebuilt set if you need new ones
Old Sep 8, 2008 | 05:20 PM
byronhunter's Avatar
byronhunter
Have you changed tires or wheels recently. Some times tire shops take a wheel that was on one side and put it on the other side.
Old Sep 8, 2008 | 07:41 PM
LATNC3's Avatar
LATNC3
battery is old..not original. tires have not been changed. the problem has been getting worse each day. always telling me i have a low tire!!!
Rod
Old Sep 8, 2008 | 10:43 PM
IzzyRI's Avatar
IzzyRI
R DEVIL is probably correct, the battery is weak but not the 12V one under the hood; the battery in the TPM sensor. Most OE suppliers of TPM systems suggest nominal life of 5-7years. This of course varies widely and is wholly dependent on driving habits; less miles driven equals longer life. When the wheel is not in motion the sensors "go to sleep" then wake when a threshold speed is reached, usually in the 10-12 mph range. Prove it to yourself, start the car cold then immediately try to read tire pressure. All zeros until threshold speed is met. Anyway, I have seen several sellers or TPM sensors that replace the battery only. Somehow they are able to "un-pot" the sensor then replace the battery. I have not used one of these however if you have an early C5, the TPMS can be pricely. BTW, I too have a '98. Hope this helps.
Old Sep 9, 2008 | 11:01 AM
LATNC3's Avatar
LATNC3
ahhhhh...tpm sensor batteries.
Old Sep 10, 2008 | 10:32 AM
Corvette Don
This is true but I have taken apart many 97-98 sensors that were dead and the battery has leaked causing the sensor to short out and rendering it to be un-rebuildable.
Old Sep 14, 2008 | 11:15 PM
LATNC3's Avatar
LATNC3
Thanks for the info guys. \i think i need new sensors.
Old Sep 15, 2008 | 01:11 AM
Mabolzich's Avatar
Mabolzich
I had that problem when I first got my 98. Then I pumped the tires up from 28 lbs. to 34 lbs. and it went away. I think 28 is a little low. The guy I got it from said that the dealer told him 26 to 28 lbs and he always had trouble with the sensors. Plus I got a letter from Obama thanking me for increasing the tire pressure as per his instructions for saving fuel. It changed my life.
Old Sep 15, 2008 | 01:59 AM
LATNC3's Avatar
LATNC3
well, i just pumped mine to 30 on my dial and they dash now reads 29 and holding. so i will keep an eye on it and see.
Rod
Old Sep 15, 2008 | 09:04 AM
510picker's Avatar
510picker
I am new to the C5 world and am curious what this would do.
Old Sep 15, 2008 | 09:19 AM
j84buick's Avatar
j84buick
Each wheel has it's own sensor that is programmed to the car. So if they put new tires on and installed the wheel that used to be on the passenger front to the driver front your DIC will be reversed since the computer still thinks the wheels are in the same spot.
Reprogramming your tire sensors takes about 5 minutes and an old speaker magnet.
Old Sep 15, 2008 | 09:49 AM
510picker's Avatar
510picker
Perfect explaination.....Thanks! I'll do a search on reprogramming the sensors.
To Tire pressure problems
