Breathless Performance C5 Headers.....
Old Jan 6, 2002 | 03:56 PM
movinup's Avatar
movinup
Default Breathless Performance C5 Headers.....
Has anyone seen the new headers from Breathless for the C5
and what is your opinion of them?
Old Jan 6, 2002 | 04:22 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Default Re: Breathless Performance C5 Headers..... (movinup)
I think Fubu69, Les....is running them, but you'll probaly find him on another forum, I'll see if I can find his email addy :cheers:
Old Jan 6, 2002 | 04:55 PM
movinup's Avatar
movinup
Default Re: Breathless Performance C5 Headers..... (Mean Green 2000)
Thanks Mean Green
Old Jan 6, 2002 | 05:00 PM
oceanaire's Avatar
oceanaire
I watched them (BPP) install a set on someones C5. They had a bit of a problem installing them. It was the fit of the header sections. They said the last ones they put on, went on with ease. I would say it was a manufacturing error. They look really sharp, but are a bit pricey. You know, nothing against Breathless or Ernie, but a lot of their stuff is pricey. Haven't seen any dyno results yet.
Old Jan 6, 2002 | 08:30 PM
movinup's Avatar
movinup
Default Re: Breathless Performance C5 Headers..... (oceanaire)
Thanks Oceanaire. I am trying to decide which LT to go with
and want to do my homework.
Old Jan 6, 2002 | 08:33 PM
oceanaire's Avatar
oceanaire
I decided to go with TTS. They came highly recommended by Mike Norris of Norris Motorsports in Orlando, FL.
Old Jan 6, 2002 | 09:55 PM
movinup's Avatar
movinup
Oceanaire,
I've also been looking at TTS and like them. I liked the idea
of Breathless where you do not have to remove the whole
header to do a cluch replacement. They also looked like an
easy install. I was wondering about the dificullty of installing
the TTS, since I would like to do the install myself.
Old Jan 6, 2002 | 10:04 PM
oceanaire's Avatar
oceanaire
The BPP looked pretty snazzy. IMO it's a good design. Don't know about installation of the TTS's. Mike Norris did mine. Eric
Old Jan 6, 2002 | 10:21 PM
movinup's Avatar
movinup
Oceanaire,
Thanks for the info.
Old Jan 6, 2002 | 11:58 PM
R BONUS's Avatar
R BONUS
I'm with Oceanaire, had Mike Norris install TTS headers. :smash: I chose them because anything anybody had to say about them was always good.
I have a 4 post lift I park my car on, so I have checked them out and they seem to be a quality piece. :cheers:
Jim
Old Jan 7, 2002 | 02:51 AM
C5go's Avatar
C5go
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
When you get them (whichever set you choose) on let me know, wouldn't mind hooking up with you and checking them out. I'm only about 1/2 hour away from you. I've been thinking about putting a set on mine. If you're serious about doing it yourself, I could give you a hand if you so desire. Keep me informed. Also, think seriously about doing a dyno before and after.
Old Jan 7, 2002 | 07:17 PM
movinup's Avatar
movinup
Default Re: Breathless Performance C5 Headers..... (C5go)
Thanks C5go'
I would be very interested in hooking up and compare notes.
Old Jan 11, 2002 | 06:21 PM
C5go's Avatar
C5go
Cruise-In V Veteran
Let me know what you decide. I've been checking myself, it looks like the BPP headers have some merit, not to mention and easier install. Check out there web site on them
Old Jan 11, 2002 | 10:47 PM
ecvette's Avatar
ecvette
Before you pick check out Finish Line Performance. Kit comes with long tube headers, high flow cats, off road pipes, ( cats V-clamp in off road pipes exchange) Y-pipe, and O2 sims. They will be available Feb. I talked to them today and they said first 25 sold will go for $1295.00. I have a proto type set. Install is easy. Left side from bottom, right side from top. No welding,no jacking engine up, and no starter removal. Kit goes from head to muffler flages.
12.05 best before headers
11.73 best after headers on motor
11.20 best with 150 shot before headers
10.82 best with 150 shot after headers at 3700' air correction
Old Jan 12, 2002 | 02:19 AM
LG Motorsports's Avatar
LG Motorsports
Premium Supporting Vendor
St. Jude Vendor Donor '03-'04-'05-'06-'07-'08-'09-'10-'11
Default Re: Breathless Performance C5 Headers..... (ecvette)
ecvette,
Aren't the FLP headers just TPIS with removable cats and off road pipes using v clamps? Correct me if I am wrong, but I believe they are a short (18") primary, just like the TPIS. that would make them a "Mid Length" header.
Thanks,
Lou Gigliotti LG Motorsports
[Modified by LG Motorsports, 6:20 AM 1/12/2002]
Old Jan 12, 2002 | 02:22 AM
intel55's Avatar
intel55
Default Re: Breathless Performance C5 Headers..... (LG Motorsports)
ecvette,
Thanks,
;) :yesnod:
:flag
Old Jan 12, 2002 | 04:25 PM
ecvette's Avatar
ecvette
Lou
You might be correct. I,m not an expert on header design. I have seen the TPIS headers and there not the same. FLP did the design from the heads to the muffler flange. I liked the idea that the headers, cats or off road pipes, and the Y-pipe were designed and tested together. I wish I could have dyno tested before and after headers but the guy that had the dyno here sold it. I made three runs with g-tech before headers on motor. Car was very consistent. 12.05, 12.09, 12.10. After headers 11.73,11.79, 11.78. The tests were done just before headers were installed and one day after. Conditions were the same. All I know is 3 tenths is an excellent gain. Granted the car has head,cam,intake and the stock exhaust was holding me back more than if it were all stock. FLP told me they dynoed a stock vette and got 25hp.
Ed Crowe
Old Jan 12, 2002 | 04:58 PM
ZO6Bill's Avatar
ZO6Bill
The Breathless headers as well as the LG Motorsports headers were recomended to me by my tuner, but I had the TPIS and couldn't sell them in time to have to put the pipes on the car. So I'm using TPIS now. :cheers:
To Breathless Performance C5 Headers.....
