Engine mods round 2
Old Sep 19, 2008 | 10:00 PM
chevy406's Avatar
chevy406
Default Engine mods round 2
This weekend I jumped into my second round of engine mod'ing. The first iteration was cam only, with typical exterior bolt-ons. After 8 months, I became tired of 380 rwhp so I dug into my Nova's budget and bought a set of AFR 205 heads, a Comp 224/230 @111°+1° with .601"/.605" lift, LS7 lifters, and ARP hardware. Last night I spent 1½ hours pulling the intake, coils, rocker arms, alternator & headers. This evening I snatched out the radiator, steering rack, harmonic balancer, and swapped in the new cam. After a little computer break I am going to button up the timing cover and ****** the heads off. It's going a lot easier on the harmonic balancer and steering rack this second go-around. The Powerbond balancer was easier to get off than the stock one because it has the 3 tapped holes for a standard balancer puller
Old Sep 20, 2008 | 08:53 PM
tlc0706's Avatar
tlc0706
More guts than I have Keep us up to date on your major mod
Old Sep 21, 2008 | 11:38 PM
chevy406's Avatar
chevy406
Well, it all came to a screeching halt when I checked piston to valve clearance. My valves on the milled AFR heads are actually contacting the pistons slightly. Looks like I will be ordering a set of fly cutters in the morning.
Old Sep 22, 2008 | 12:19 AM
lucky131969's Avatar
lucky131969
Seems the cam change would have been easier with the heads off.......
Old Sep 22, 2008 | 11:11 PM
tlc0706's Avatar
tlc0706
Ouch
Old Sep 23, 2008 | 05:31 AM
vettenuts's Avatar
vettenuts
If you are contacting, you are going to have to go pretty deep. Any thought to reducing the cam duration and widening the LSA to pick up the clearance?
Old Sep 23, 2008 | 07:57 AM
lucky131969
Just curious, were you just flying by the seat of your pants, or did someone recommend the cam/head setup?
Old Sep 23, 2008 | 10:27 AM
chevy406's Avatar
chevy406
I am just flying by the seat of my pants.
Last night I had an "ah ha" moment. Initially I was using a 7.400" push rod and light weight checker valve springs. Since these springs did not compress the lifters, the valves were not able to close all the way. When I swapped in my adjustable pushrod, the valve interference went away. Tonight I'll go back to checking PTV clearance using the adjustable pushrod set to the proper length (ie subtract out the lifter preload). While this was a rookie mistake, I will learn from it and no harm was done.
To Engine mods round 2
